Old 01-15-2009, 11:52 PM
acacia acacia is offline
Default It there a trick to smoothing with beat detection?
Hey All,
Any chance there's an easy way to avoid having to clean up after smoothing (fill and crossfade) drum tracks with beat detection. I'm sure some ones itching to say Elastic Audio but seriously is there? I'm cleaning up a ton of drum sessions this week and I'm sick of chasing down stuttered hits after every things been tightened up. Elastic audio has been hit or miss for me since it first came out so I've been sticking with old faithful. I'm pretty sure the beat detection cleanup isn't avoidable. I just thought I'd try and step out of my box... Maybe that step should be giving EA another chance with PT8 . Thanks!
Luke Rohwer
Acacia Recording & Production
www.acaciarecording.com
Luker[at]acaciarecording[dot]com
Studio 301-703-0035
Old 01-16-2009, 12:58 AM
EvilElfBoy EvilElfBoy is offline
Default Re: It there a trick to smoothing with beat detection?
There really is no way to avoid the stutter effect that sometimes beat detective will do if the drums aren't close enough to the grid you are using. Manual pocketing is probably your best bet, hence why good editors get paid good money for all the tedious work that most do not want to deal with.
EA if used correct will give really great results. The trick to using EA is that YOU MUST create an edit group for the drums when quantizing. if not you will lose all phase coherency and it will sound awful. I would go in small sections and fix whatever warp triggers that have either moved in the wrong direction or just should not be there.
It's pretty easy once you get used to it, especially if you want quick results with a lot of editing time saved.
Give it a whirl. :)
AKA - EvilElfHobo
Pro Tools 10 HD Native | Mbox 3 Pro | MacBook Pro 2.3 i5 | OSX 10.7.4
Pro Tools Music & Post Operator V6-8, Instructor, and Expert ICON Mixer Certified.
Multi-Platinum Pro Tools Videos
Old 01-16-2009, 05:38 AM
Drew Mazurek's Avatar
Padding your triggers helps. I usually set it to 3-5ms.
www.drewmazurek.com
Old 01-16-2009, 06:03 AM
Ru_C Ru_C is offline
Not that it helps you so much now, but i use a session drummer who plays very solidly, fantastic kit etc..but always *just* ahead of the damn click.
I've taken to delaying the click in his headphone by about 1/128 note, & bingo, problem solved....
If you find that your recorded drums are always a bit ahead, & you know that you are going to beat-detective the whole track...there is nothing to stop first you sliding *all* the drums back a bit, so the vast majority of the hits fall just the right side of the grid.
Now when you go to BD them, there will be much less manual fixing of flamming edits ...
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2023.6 Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES
B Rig: (Home/Office). M1 Mac Studio - 64gb ram - OSX 12.7.1, PT Ultimate2023.6, HD Native Thunderbolt, Omni, Avid Artist Control
http://www.lostboysstudio.com
Old 01-16-2009, 07:53 AM
smlworld smlworld is offline
Originally Posted by acacia View Post
Hey All,
Don't know if you are familiar with Kenny Giola videos. The guy is pretty genius.
http://www.grooveboxmusic.com/str/pr...tricks-v1.html
you might find some for free on the net or on the duc. he is REALLY good with beat detective.
[img]/images/graemlins/tongue.gif[/img] <<<<< in the psychiatric emergency handbook this is bad news.
Old 01-16-2009, 05:25 PM
Thanks guys!
I'm gonna try padding the triggers like drew suggested for this next song. Back when EA was first introduced I spent time chasing multi track EA with grouping... and found it to be hit or miss with phase issues. Specifically room mic tracks. It seemed like some rooms just wouldn't work but if the tracks were pretty dead / void of ambience EA work really easy. I've had a few guys mention that with the last few PT versions / cs updates they've seen improvement. So I'll give that a try again. Ru_c, that's a slick trick. The session players I usually use are pretty dead on. Unfortunately this project didn't use a session player and the guy was all over the map so sliding the drums closer to the grid wont really help. It's work but it pays :) So I can't really complain. smlworld - yes I'm familiar with Kenny Giola's videos. thanks for the link. You guys are awesome!
Luke Rohwer
Studio 301-703-0035
Old 01-16-2009, 09:45 PM
Curiosity got to me and I gave EA another shot before going back to BD. I have to say EA is much improved since early 7.4. I'll mess with padding the triggers a little later but so far I'm getting great / fast results with EA.
Luke Rohwer
Studio 301-703-0035
Old 01-18-2009, 01:51 AM
Hey Drew, Thanks for the tip with Padding my triggers. That made a huge difference!
Luke Rohwer
Studio 301-703-0035
Old 01-18-2009, 05:14 AM
Glad to help. I knew it would it make a big difference.
www.drewmazurek.com
Old 01-18-2009, 11:22 AM
Kenny Gioia Kenny Gioia is offline
Trigger pad can make a huge difference depending on how it was recorded.
I never ever need it. But for some it seems to fix right up.
It must have to do with how BD analyzes transients.
I've received tracks from others where the fades are right on the transient. That's not good. Mine seem to always be right before with no pad. Oh well.
beat detection - pro tools update ruffwoods 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-01-2011 03:15 PM
beat detective for edit smoothing raindog Post - Surround - Video 0 08-15-2007 03:29 AM
Beat Detective Edit Smoothing broken in PT7? beggehorn Pro Tools TDM Systems (Win) 6 12-14-2005 01:57 PM
Beat Detection March314 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-16-2005 07:42 AM
Beat Detective - Edit Smoothing bassmac Pro Tools TDM Systems (Mac) 1 12-28-2002 04:14 PM
