Old 10-23-2016, 10:04 AM
PJ Brady PJ Brady is offline
Default Waveform Size
Dear friends.
I am having problems with the size of the waveforms when recording. Basically, the input levels are correctly set, the channel meter's are safely indicating between -9db to -6db yet the visual waveform on the recorded clips are massive. To the point that one would assume that they are clipping. On play back the sound is fine. I would like to stress that it is not a zooming issue as suggested on other threads. I have tried this and even as far as I can zoom out the problem remains. Many thanks.
Old 10-23-2016, 10:38 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Waveform Size
Zooming in and out doesn't change the height of the waveform.
On Windows, Alt+Shift+Scroll will lower or raise the height of the waveform. On OS X, I believe it's Option+Shift+Scroll.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 10-23-2016, 10:50 AM
Many thanks
Old 10-23-2016, 10:58 AM
The Weed's Avatar
Glad I could help.
SonoBus
Old 10-23-2016, 11:10 AM
soybalm soybalm is offline
There's also a little button with a wave on it usually near the top left side of the screen. If you press the bottom, it makes the wave smaller and vice versa.
Dave Cournoyer-guitarist-project studio
Mac Mini late 2012, i7, Sierra
16GB PT10.3.10HD PT12.5.2
Apogee Mini-Me firewire.
Old 10-26-2016, 03:18 PM
Yeah thanks. I am new to PT so I do expect a few school boy error's
Many thanks.
Old 10-26-2016, 05:36 PM
Drew Mazurek's Avatar
Option-A (or double clicking the Magnifying Glass tool) will reset both vertical and horizontal waveform views.
www.drewmazurek.com
Old 05-14-2020, 06:50 AM
Antonella Antonella is offline
I was having the same problem!!! Option A worked perfectly! Thank you!!
Old 05-15-2020, 08:57 PM
Muddy-T's Avatar
Muddy-T Muddy-T is offline
One more useful keyboard shortcut; ctrl+alt+cmd+[ to reset all to (vertical) default size.
T
"Don't look; listen!"
At work; 2013 27" iMac/i5/2.9GHz/8GB, OSX 10.8.5, PT 10.3.6
At home; Custom Made Mac (Hackintosh) i7 (3770 "Ivy Bridge")/3.4GHz/32GB@2400MHz, Samsung SSD 840 EVO 250GB System Drive, Samsung SSD 750 EVO 250GB Audio Drive, OSX 10.10.5, PT 12.8.1
Waveform size mickeyrouse Tips & Tricks 5 02-02-2014 10:16 PM
Waveform size bug ? Firechild Pro Tools TDM Systems (Mac) 4 02-06-2012 10:29 PM
waveform have different size why nossnevs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-19-2007 04:07 PM
Waveform size, not track size Bleitner Pro Tools TDM Systems (Mac) 3 11-03-2005 02:39 PM
Waveform size remote Pro Tools TDM Systems (Mac) 2 02-25-2003 10:06 PM
