How master faders do you usually run?
I just use one. Lately I have read on forums to try usually more than one master fader. Does anyone do this?
My Official Website My Official Music Forum Myspace Page Soundclick My Youtube Channel |
Re: How master faders do you usually run?
I know you'll get lots of opinions here. I use none. I just go for the best mix I can do and leave any master stuff to be done in mastering. The extra step is worth it for me.
I do one master, and I generally put mastering plugs in it (usually just T-Racks Soft Clipper or Sony Inflator). If it's going to be mastered elsewhere I simply disable them for the bounce, but I prefer to mix with some idea of how it will sound after mastering.
For mixing live multitrack I subgroup the direct mix to an aux (no plugs) and balance against the room mics (with plugs). Not sure if that's what you meant though. I think a more interesting question is how many effect aux's people run. I run anywhere from 5-8. I use different reverbs and delays for different aspects to create depth and space. |
i mix to sub groups then a master bus so an Aux track is basicly my master.
why would you need more than one master fader?
that being said while I only use one master fader while tracking and mixing but i don't put any plugins on it, i just use it to make sure i'm not clipping
www.klarityrecordingstudios.com |
When tracking I can use up to 8 master faders. I use one master fader on each analog output (usually 6 analog outs for headphone mixes, and 1 stereo master left/right).
When mixing I use one master fader. I also mix to subgroups, all bussed to one "master" stereo bus. This bus is the only thing going to the master fader. My master fader only has dither on it. Check out this link to a post from nikki-k about master faders. Master Faders
https://www.thirdeyerecording.com/ |
I typically mix my project with one master fader, group all faders bring em downto where there are practically no clips..then put a slight limiter on it.
The only reason I would ever have a few masterfaders would be for more control on multi band compression. I've never experimented with it but I guess you could create a few, put a high cut/low cut/some band pass eq's and compressors on each fader and then blend them. I've done it in other programs but never tried it in pro-tools....be carefull for phasing if you overlap some freqs. You'll hear those pockets drop out and it will make you queezey!!!!!! |
thx Third Eye! I forgot about that post...lol...
Master Faders are so misunderstood...but, so is much of PT stuff, and even DAW theories in general. Plus, since gain structuring differs (slightly, at the least) between TDM and Native (LE, MP), understanding is further clouded for some (many?). One of the things many do not realize is that Master Faders exist ALREADY for EVERY buss and every output. Have 4 active Outputs? Think of those Outputs as being busses to the physical outputs themselves...and as such, being busses, they have Master Faders inline, just prior to leaving. Once you realize this, then it is time to understand HOW those Master Faders can be of use. Maybe others can provide their "tips n tricks of MF usage"?
nikki k Eagles may soar, but weasels don't get sucked into jet engines. On the other hand, you have different fingers. |
If you are bouncing to disk internally, than one master fader is fine. Using none is gambling (with yours or a clients material) because you can't see when it clips. Using 4 or 5 is overkill... someone give me a reason based in fact why you need more than one for a stereo recording bounced in the box.....
Master Faders | nate9 | ICON & C|24 | 24 | 01-20-2009 02:11 PM |
Master Faders Button on 002 | shareec70 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-25-2006 08:53 PM |
Are master faders really necessary??? | AppleFunk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 22 | 01-30-2004 04:54 PM |
Multiple Master Faders?? | rfreeman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-17-2002 08:17 PM |
Master faders and DSP | Psonic Psunspot | Tips & Tricks | 1 | 12-23-1999 01:51 PM |
