Re: New MacPro HDMI
Yes people used the Canopus. Could they judge sync with it? People who use a monitor just need to know sync with vary and be ok with it.
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
Re: New MacPro HDMI
Surely they could judge sync or it wouldn't have been used? I've not seen any variation in sync with PT11
Re: New MacPro HDMI
Pt11 has the same issues that pt 10 has, or any other non gen locked system. The 2 systems don't know where the frame starts, so it doesn't start in sync, and the two systems don't know how fast the other is going so they drift. The amount will vary vary but, I can tell my clients with 99.9% accuracy that the sync they see is right. I've worked in facilities that just let pt fly without gen locking anything and had clients ask me if something is in sync. I can't answer them.
Re: New MacPro HDMI
When you say it doesn't know how fast it's going, surely it does as it knows the frame rate. Are you suggesting Media Composer has the same issues? If it doesn't, there's no reason Pro Tools should. I'm just amazed Pro Tools can't do something so basic without a Sync HD. Ironically Avid only say you must have a Sync HD if you use a Mojo DX. In this day and age Pro Tools should be able to provide reliable sync internally. Now they control the video engine too, there's nothing to stop the 2 being locked together at the session frame rate. |
Re: New MacPro HDMI
Well written!
Michael Goorevich Sound Designer / mixer www.goorevich.com PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3 MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24 |
#16
Re: New MacPro HDMI
I know there is a lot of mis-information around, so it would be nice for someone from Avid to comment. Perhaps Media Composer does run video and sound separately too and hopes for the best, I somehow doubt that though. I remember a few years ago, just around the time BM cards support was added to Pro Tools, talking to someone from BlackMagic Design at the BVE in London and asking him if Pro Tools definitely needed bi or tri-level sync when working with their cards. His reply was something like "if Pro Tools needs bi/tri-level sync to run video internally and keep accurate sync (i.e. using a BM card and no decks), then something is very wrong with Pro Tools" |
#17
Re: New MacPro HDMI
Without house sync, your video i/o and audio i/o will not be locked together. When you say PT11 has "better" sync due to AVE, what exactly, are you saying? What are the new sync parameters? PT with sync reference has something like +- 3 samples. I like being confident that I'm in sync, not just guessing.
#18
Re: New MacPro HDMI
I fully accept that for video IO and audio IO to be locked you need ref. However, if you are playing video through a Mac HDMI connection where you are able to set the refresh rate to a multiple of your frame rate (which you are), Pro Tools should be able to play audio and video at the same rate, instead of starting them separately and letting them run independently, unlocked. Frame edges could be determined from the video file, you shouldn't need a Sync IO to ensure that. I'm not talking about what happens at the IO end, but internally within Pro Tools. Are you able to comment on my questions about Media Composer? Lots of editors use that without hardware and don't seem to have issues with sync drifting, so I assume the 2 are locked together internally. |
#19
Re: New MacPro HDMI
No I can't. I just know the facts about pro tools and it's requirements. I will say I tested pt 11 for sync and I still found drift of more then a frame after 10 minutes of play.
#20
Re: New MacPro HDMI
Fair enough, thanks for that Brandon. Would be interested to see what Avid have to say on the matter. I assume this is with a BM card instead of internal video window?
USB-HDMI adapters???? | albee1952 | Pro Tools HDX & HD Native Systems (Win) | 14 | 10-17-2013 06:33 AM |
anyone have any experience with Arvus HDMI-2a HDMI to 8 ch AES | Craig F | Post - Surround - Video | 0 | 12-17-2012 04:24 PM |
Using carbon copy to move from macpro to a newer Macpro | fourthtunz | Pro Tools TDM Systems (Mac) | 2 | 04-10-2012 02:39 PM |
USB to HDMI | lode | Post - Surround - Video | 5 | 11-17-2008 12:00 AM |
Asus m3n-hd hdmi ??? | halipino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 20 | 08-01-2008 10:06 PM |
