Old 04-28-2011, 05:35 AM
qbert1 qbert1 is offline
Default "Bus error" in "Main Thread", at address 0x0
Hope someone can help. I've searched and tried everything I found with no luck so far.
I just bought a new MacBook Pro 13" - 2.3Ghz Intel Core i5 4Gb 1333 Mhz DDR3 Ram. Did a clean install of the OS. Tried to install PTLE 8.0 and got stumped with an error message ""Bus error" in "Main Thread", at address 0x0" when ever I started a new session or opened up a existing one.
Then attempted to install 8.0.1 in hopes it would be fixed. Installation "failed" due to some Interlok thing that I can't remember. Seems 8.0.1 may have been installed anyway, but same error appears when I start or open a session.
BTW, error occurs with 002r and Mbox.
I think I went through all the general trouble shooting suggestions, but feel free to make any suggestions. Need help ASAP.
Old 04-28-2011, 08:34 AM
DigiTechSupt's Avatar
DigiTechSupt DigiTechSupt is online now
Default Re: "Bus error" in "Main Thread", at address 0x0
Which OS version are you running?
Typically this is caused by a corrupted install - a clean uninstall, restart and reinstall should take care of it, though knowing which OS version you're on would help, as that may be a contributor.
Avid Audio Tech Support
Support FAQ
Old 04-28-2011, 08:45 AM
Thanks for the help. I'm using Snow Leopard - I forget which version number that is. Perhaps 10.6.7 if I recall correctly. Not near that mac at the moment. I'll update if I find I'm wrong.
If it helps, this has been the third install. The second one where I start from a completely fresh mac OS. Each time the issue persists.
I'm hoping to stay with 8.0.1 so I can use my mbox occasionally when I'm away from my rack.
Mac i5 2012 "Bus Error" in thread "Main Thread", at address 0x0 tony20970 macOS 2 01-29-2014 10:45 PM
"Bus error" in thread "Main Thread", at address 0x0 unexplainedbacon Pro Tools 10 5 11-26-2012 06:12 AM
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 danball macOS 2 09-26-2011 04:49 PM
"Bus error" in thread "Main Thread" address 0x0 briantar1 macOS 1 05-28-2011 04:34 PM
"Segmentation Fault" in thread"Main Thread" at address 0x0 refuu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-13-2011 05:18 AM
