axiom 25 and protools 7
I have been trying to figure out how to get my axiom 25 to register and play in pro tools. Im obviously new to this. I watched the pro tools method one video and read the axiom and pro tools help manuals but i still can not figure it out.
I installed the axiom 25 driver and created the instrument in pro tools midi setup. Im connected with a usb port and when your creating your instrument it asks for the in port and out port. If im using a usb connection what do Input? My midi thru is enabled I have sampletank setup, it will load but there are no instruments listed. i have all the files saved in c:\program files > common files > digidesign > DAE > Plug-ins but i think this is seperate problem from the original question i asked. Any help would greatly appreciated thanks, john |
Re: axiom 25 and protools 7
You shouldn't have to if you followed the default install, but you may also need to tell the plugin what that root folder for the instruments is. The Sampletank manual is installed with the plugin and is available from the start menu. Here is an excerpt from it about setting the root folder: Quote:
thanks spkguitar.
I am using sampletank2. Ok. So my axiom is showing up on my mix window and I am getting a signal but I have no sound. Im running studio monitors through my mbox2. I had all sampletank files loaded to the default browser like the instructions said, and then loaded the instruments into program files > common files > digidesign > dae > plug-ins but sample tank wouldnt load error 7401 ( I think ), so I searched the IK website and it told me to load all the files into program files > common files > digidesign > dae > plug-ins. I did that and it sample tank loads now, but I dont have any instruments. I havent had a chance to try what you have previously suggested. Thanks again. |
thanks spk Ill let you know how i goes
thanks spk. for all the help I finally got it working.
hey, boostedrsx,
how is that axiom25 working? I really have my mind set on getting one... I need drum pads, but not 16! Thanks! Dave Kutch |
Protools SE and Axiom 49 | Rusty Shackleford | Pro Tools SE and Essential (Win) | 0 | 03-09-2013 04:48 PM |
axiom 25 / ProTools - not working! | ivnamei | Pro Tools M-Powered (Win) | 4 | 10-02-2009 07:15 AM |
Axiom 61 Map For Protools | Dre B Vibe N | Pro Tools M-Powered (Win) | 0 | 01-14-2009 07:10 AM |
Cant control protools with an Axiom 49 | Amnesiac | MIDI | 4 | 02-10-2008 02:02 PM |
Axiom 25 into protools via usb or via mbox2 help! | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 07-26-2006 01:40 PM |
