PT 9 HD loop crash causes Kernal Panic
Hi
Just bought a new Westmere Mac Pro and have a fresh install of PT9HD. Running OSX 10.6.5 Have experienced 4 Kernel Panic's in 4 days. They all occur when i try to relaunch PT after a crash quit. One crash-quit-Panic was after i tried to instantiate Izotope Ozone 4 and received a "Fatal Error" message. The other 3 have occurred when i'm simply playing and the playback goes into a short loop (ie. repeats a second or so of playback about 3 times) then crashes. I can't say i can repeat the action to cause Protools to crash, but i can guarantee once it does it will cause a Kernel Panic if i try to relaunch. All plugins are the latest installers on a brand new computer. Anyone else getting this? Should i post my crash logs? fman |
Re: PT 9 HD loop crash causes Kernal Panic
So i just had another Kernel Panic, and this was AFTER a complete Prefs/database clear-out using the Preference helper, after a crash.
Something isn't right here. |
Firstly if PT crashes or freezes you must always re-boot the mac!! download and run this plugin lister and copy paste the generated plugin list here... unzip/run and wait till close window message appears!!! http://www.sendspace.com/pro/dl/9xyx8w Crash logs are in user/library/logs/diagnostic reports at the top of the crash log it will indicate which thread has caused!!! for now just copy the thread which has crashed, and paste it here. Chris
Ok happened again.
Here is the crashed Thread: Process: Pro Tools [231] Path: /Applications/Digidesign/Pro Tools/Pro Tools.app/Contents/MacOS/Pro Tools Identifier: com.digidesign.ProTools Version: 9.0.1 (9.0.1f41) Code Type: X86 (Native) Parent Process: launchd [124] Date/Time: 2011-01-10 12:32:52.959 +1100 OS Version: Mac OS X 10.6.5 (10H574) Report Version: 6 Exception Type: EXC_CRASH (SIGABRT) Exception Codes: 0x0000000000000000, 0x0000000000000000 Crashed Thread: 0 Dispatch queue: com.apple.main-thread Application Specific Information: abort() called Thread 0 Crashed: Dispatch queue: com.apple.main-thread 0 libSystem.B.dylib 0x9255f176 __kill + 10 1 libSystem.B.dylib 0x9255f168 kill$UNIX2003 + 32 2 libSystem.B.dylib 0x925f189d raise + 26 3 libSystem.B.dylib 0x926079bc abort + 93 4 libstdc++.6.dylib 0x99210fda __gnu_cxx::__verbose_terminate_handler() + 433 5 libstdc++.6.dylib 0x9920f17a __cxxabiv1::__terminate(void (*)()) + 10 6 libstdc++.6.dylib 0x9920e51d __cxa_call_terminate + 53 7 libstdc++.6.dylib 0x9920f09d __gxx_personality_v0 + 911 8 libSystem.B.dylib 0x9256d54d unwind_phase2 + 205 9 libSystem.B.dylib 0x92583f19 _Unwind_Resume + 73 10 com.digidesign.framework.DAE 0x03e8bdbf FWAudioCallback + 206489 11 com.digidesign.framework.DAE 0x03e5e80f FWAudioCallback + 20713 12 com.digidesign.framework.DAE 0x03ea6726 FWAudioCallback + 315392 13 com.digidesign.framework.DAE 0x03ed07a0 FicPrepareForConnections + 114 14 ...gidesign.framework.ProTools 0x00fca6eb MFortressHWBPEntryPoint_exit_mfort6317_ + 6616366 15 ...gidesign.framework.ProTools 0x00fca77d MFortressHWBPEntryPoint_exit_mfort6317_ + 6616512 16 ...gidesign.framework.ProTools 0x00e9d4ed MFortressHWBPEntryPoint_exit_mfort6317_ + 5382960 17 ...gidesign.framework.ProTools 0x00e329ab MFortressHWBPEntryPoint_exit_mfort6317_ + 4945902 18 ...gidesign.framework.ProTools 0x00ef294c MFortressHWBPEntryPoint_exit_mfort6317_ + 5732239 19 ...gidesign.framework.ProTools 0x00ed6288 MFortressHWBPEntryPoint_exit_mfort6317_ + 5615819 20 ...gidesign.framework.ProTools 0x01c327f8 MFortressHWBPEntryPoint_exit_mfort6317_ + 19625531 21 ...gidesign.framework.ProTools 0x0151f9ea MFortressHWBPEntryPoint_exit_mfort6317_ + 12208173 22 ...gidesign.framework.ProTools 0x015326f3 MFortressHWBPEntryPoint_exit_mfort6317_ + 12285238 23 ...gidesign.framework.ProTools 0x01968a66 MFortressHWBPEntryPoint_exit_mfort6317_ + 16701609 24 com.digidesign.framework.DFW 0x03018e85 TCommandHandler::PerformCommand(TCommand*) + 251 25 com.digidesign.framework.DFW 0x0301944b TCommand::Process() + 31 26 ...gidesign.framework.ProTools 0x0152503b MFortressHWBPEntryPoint_exit_mfort6317_ + 12230270 27 ...gidesign.framework.ProTools 0x0196f4c5 MFortressHWBPEntryPoint_exit_mfort6317_ + 16728840 28 com.digidesign.framework.DFW 0x03018e85 TCommandHandler::PerformCommand(TCommand*) + 251 29 com.digidesign.framework.DFW 0x0301944b TCommand::Process() + 31 30 com.digidesign.framework.DFW 0x0301135e TApplication::ProcessEvent(TEvent*) + 26 31 com.digidesign.framework.DFW 0x030115b8 TApplication::WakeUp() + 64 32 com.digidesign.framework.DFW 0x03122c93 TApplication::GetApplicationVersionComponents(Cmn_ PolyVector<long, false>*) + 5659 33 com.apple.HIToolbox 0x99705f2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567 34 com.apple.HIToolbox 0x997051f6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411 35 com.apple.HIToolbox 0x99705055 SendEventToEventTargetWithOptions + 58 36 com.apple.HIToolbox 0x99739bb0 ToolboxEventDispatcherHandler(OpaqueEventHandlerCa llRef*, OpaqueEventRef*, void*) + 3006 37 com.apple.HIToolbox 0x99706380 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672 38 com.apple.HIToolbox 0x997051f6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411 39 com.apple.HIToolbox 0x997279bb SendEventToEventTarget + 52 40 com.apple.HIToolbox 0x998b0cc3 ToolboxEventDispatcher + 86 41 com.apple.HIToolbox 0x998b0dfb RunApplicationEventLoop + 243 42 com.digidesign.framework.DFW 0x03129365 DFW_EventLoop::RunApplicationEventLoop() + 11 43 com.digidesign.framework.DFW 0x03010f7f TApplication::Run() + 45 44 ...gidesign.framework.ProTools 0x01db8116 LaunchProTools + 5121 45 com.digidesign.ProTools 0x0000f735 0x1000 + 59189 46 com.digidesign.ProTools 0x0000e98f 0x1000 + 55695 47 com.digidesign.ProTools 0x0000e8bd 0x1000 + 55485 |
and here is my plugin list:
Mon 10 Jan 2011 12:44:18 EST Pro Tools Version __________________________________________ Plug-In Versions __________________________________________ AIRChorus.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. AIRDistortion.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. AIRDynamicDelay.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. AIREnhancer.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. AIREnsemble.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. AIRFilterGate.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. AIRFlanger.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. AIRFrequencyShifter.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. AIRFuzz-Wah.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. AIRKillEQ.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. AIRLo-Fi.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. AIRMulti-Chorus.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. AIRMulti-Delay.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. AIRNon-linearReverb.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. AIRPhaser.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. AIRReverb.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. AIRSpringReverb.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. AIRStereoWidth.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. AIRTalkbox.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. AIRVintageFilter.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. Access Music Indigo.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Albino 3.dpm Albino Demo version 3.0.2 © 2006-2007 Rob Papen and LinPlug Virtual Instruments GmbH. Altiverb 6.dpm 6.3.5 Copyright 2009 by Audio Ease. All rights reserved. AmpegSVX.dpm AmpegSVX, Copyright 2005-2009 IK Multimedia AmpliTube1.xLE.dpm AmpliTube 1.x LE, (R)(C) IK Multimedia 2006 AmpliTube2.dpm AmpliTube 2, Copyright 2005-2009 IK Multimedia AmpliTubeJimiHendrix.dpm AmpliTube Jimi Hendrix, Copyright 2007-2009 IK Multimedia AmpliTubeLE AmpliTubeLE version 1.0.2, Copyright © 2004 by iK Multimedia. All rights reserved. AmpliTubeXGEAR.dpm AmpliTube X-GEAR, Copyright 2007 - 2009 IK Multimedia Analog Factory.dpm 2.5, Copyright 2010 Arturia Analog_Channel_HD.dpm 3.3x5, Copyright 1998-2009 McDowell Signal Processing, LLC B4 II.dpm 2.0.4, Copyright © 2005 Native Instruments BF Essential Clip Remover.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. BF Essential Corr.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. BF Essential Meter.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. BF Essential Noise.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Band Delays (Anth 2.0).dpm 1.5.1.0 (Anthology II), Copyright 1991-2009 Eventide, Inc. Battery 3.dpm 3. (R532), Copyright © 2010 Native Instruments Boom.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. Bruno.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Channel_G_HD.dpm 2.3x5, Copyright 1998-2009 McDowell Signal Processing, LLC Chorus.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Chrome_Tone_HD.dpm 2.3x5, Copyright 1998-2009 McDowell Signal Processing, LLC Click.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. CompressorBank_HD.dpm 4.3x5, Copyright 1998-2009 McDowell Signal Processing, LLC Cosmonaut Voice.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. D-Verb.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. DB-33.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. DigiReWire.dpm 9.0.1, Copyright 1991-2010 Avid Technology, Inc. Dither.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Dynamics III.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. E-Channel (Anth 2.0).dpm 1.5.1.0 (Anthology II), Copyright 1991-2009 Eventide, Inc. EMI TG 12413 UB.dpm 1.1.8, Copyright 2005, All Rights Reserved EQ III.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. EQ45 (Anth 2.0).dpm 1.5.1.0 (Anthology II), Copyright 1991-2009 Eventide, Inc. EQ65 (Anth 2.0).dpm 1.5.1.0 (Anthology II), Copyright 1991-2009 Eventide, Inc. EZdrummer.dpm © Toontrack AB 2006, Version 1.1.5 Elastic Audio.dpm 9.0.1, Copyright 1991-2010 Avid Technology, Inc. Eleven Delay UI.dpm 8.0.3, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc. Eleven Distortion UI.dpm 8.0.3, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc. Eleven Dynamics UI.dpm 8.0.3, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc. Eleven EQ UI.dpm 8.0.3, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc. Eleven FX Loop UI.dpm 8.0.3, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc. Eleven Free.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Eleven LE.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Eleven Modulation UI.dpm 8.0.3, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc. Eleven Reverb UI.dpm 8.0.3, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc. Eleven Tuner UI.dpm 8.0.3, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc. Eleven UI.dpm 8.0.4, Copyright 1991-2010 Avid Technology, Inc. Eleven Volume UI.dpm 8.0.3, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc. Eleven Wah UI.dpm 8.0.3, Copyright 1991-2006 Digidesign, A Division of Avid Technology, Inc. Eleven.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Eventide Reverb (Anth 2.0).dpm 1.5.1.0 (Anthology II), Copyright 1991-2009 Eventide, Inc. Factory (Anth 2.0).dpm 1.5.1.0 (Anthology II), Copyright 1991-2009 Eventide, Inc. Fairchild 660.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Fairchild 670.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. FilterBank_HD.dpm 4.3x5, Copyright 1998-2009 McDowell Signal Processing, LLC Flanger.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. H910 Harmonizer (Anth 2.0).dpm 1.5.1.0 (Anthology II), Copyright 1991-2009 Eventide, Inc. H949 Harmonizer (Anth 2.0).dpm 1.5.1.0 (Anthology II), Copyright 1991-2009 Eventide, Inc. Impact.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Instant Flanger (Anth 2.0).dpm 1.5.1.0 (Anthology II), Copyright 1991-2009 Eventide, Inc. Instant Phaser (Anth 2.0).dpm 1.5.1.0 (Anthology II), Copyright 1991-2009 Eventide, Inc. Invert-Duplicate.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. JOEMEEK Compressor.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. JOEMEEK Meequalizer.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. L2007 Mastering Limiter.dpm 1.3.4 (1275) "Copyright (C)2006-2007 Massey Plugins Inc., All Rights Reserved." LoFi.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. MC2000_HD.dpm 3.3x5, Copyright 1998-2009 McDowell Signal Processing, LLC Massey DTM.dpm 1.2.0 [1914] "Copyright (c)2008-2009 Massey Plugins Inc., All Rights Reserved." Massey Tools.dpm 0.5.3 beta, Copyright (c) 2007-2009 Steven M. Massey, All Rights Reserved. Maxim.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. MiniGrand.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. Mod Delay II.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Multi-Tap Delay.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Normalize-Gain.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Octavox (Anth 2.0).dpm 1.5.1.0 (Anthology II), Copyright 1991-2009 Eventide, Inc. Omnipressor (Anth 2.0).dpm 1.5.1.0 (Anthology II), Copyright 1991-2009 Eventide, Inc. Oxford Dynamics_TDM.dpm 1.6.3, Copyright 2010 Sonnox Ltd. Oxford TransMod_TDM.dpm 1.5.3, Copyright 2010 Sonnox. PTA (Anth 2.0).dpm 1.5.1.0 (Anthology II), Copyright 1991-2009 Eventide, Inc. PhilharmonikCE.dpm Miroslav Philharmonik CE, Copyright 2007-2009 IK Multimedia Phoenix.dpm 2.10.5 Copyright 2002-2009 Crane Song Ltd. Ping-Pong Delay.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Pitch.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Purple Audio MC77.dpm 7.4.2, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Quadravox (Anth 2.0).dpm 1.5.1.0 (Anthology II), Copyright 1991-2009 Eventide, Inc. RectiFi.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Reso.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Reverb One.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Reverse-DC Removal.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Revolver_Native.dpm 1.3x5, Copyright 1998-2009 McDowell Signal Processing, LLC SampleTank2.x.dpm SampleTank 2, Copyright 2001-2009 IK Multimedia SansAmp PSA-1.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. SciFi.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Signal Generator.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. SignalTools.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. SonyOxfordEQ.dpm 2.6.2, Copyright 2007 Sonnox. SoundReplacer.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. SoundToys Speakerphone.dpm 2.0.3 Copyright 2009 by Audio Ease. All rights reserved. Spectron.dpm 1.1.4, Copyright © 2006 iZotope, Inc. Structure.dpm 1.1.0.9837 Copyright 2005-2007 Digidesign, A Division of Avid Technology, Inc. Surround Mixer.dpm 9.0.1, Copyright 1991-2010 Avid Technology, Inc. Synth_One_HD.dpm 4.3x5, Copyright 1998-2009 McDowell Signal Processing, LLC T-RackS Equalizer T-RackS Equalizer version 1.2.1, Copyright © 2004 by iK Multimedia. All rights reserved. T-RackS Multiband Limiter T-RackS Multiband Limiter version 1.2.1, Copyright © 2004 by iK Multimedia. All rights reserved. T-RackS Soft Clipper T-RackS Soft Clipper version 1.2.1, Copyright © 2004 by iK Multimedia. All rights reserved. T-RackS Suite T-RackS Suite version 1.2.1, Copyright © 2004 by iK Multimedia. All rights reserved. T-RackS Tube Compressor T-RackS Tube Compressor version 1.2.1, Copyright © 2004 by iK Multimedia. All rights reserved. THC.dpm 1.0.4 (1285) "Copyright (c)2006-2007 Massey Plugins Inc., All Rights Reserved." TL AutoPan.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. TL InTune.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. TL MasterMeter.dpm 8.0.3, Copyright 1991-2009 Digidesign, A Division of Avid Technology, Inc. TL Metro.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. TRackS1.x.dpm T-RackS 1.3, Copyright IK Multimedia 2007 TRackS1.xClipper.dpm T-RackS 1.x Clipper, Copyright IK Multimedia 2007 TRackS1.xCompressor.dpm T-RackS 1.x Compressor, Copyright IK Multimedia 2007 TRackS1.xEqualizer.dpm T-RackS 1.x Equalizer, Copyright IK Multimedia 2007 TRackS1.xLimiter.dpm T-RackS 1.x Limiter, Copyright IK Multimedia 2007 TRackS3 Classic Clipper.dpm T-RackS 3 Classic Clipper, Copyright 2008 - 2010 IK Multimedia TRackS3 Classic Comp.dpm T-RackS 3 Classic Compressor, Copyright 2008 - 2010 IK Multimedia TRackS3 Classic EQ.dpm T-RackS 3 Classic Equalizer, Copyright 2008 - 2010 IK Multimedia TRackS3 Classic MBand Lim.dpm T-RackS 3 Classic Multiband Limiter, Copyright 2008 - 2010 IK Multimedia TRackS3 Metering.dpm T-RackS 3 Metering, Copyright 2008 - 2010 IK Multimedia TRackS3.dpm T-RackS 3, Copyright 2008 - 2010 IK Multimedia Tape-Head.dpm 1.3.2:1201 " Copyright (c) 2006-2007 Steven M. Massey, All Rights Reserved." Tel-Ray Delay.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. The Glue.component Copyright 2009 Cytomic The Glue.dpm Copyright 2009 Cytomic Time Comp-Exp-Pitch Shift.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Time Shift.dpm 8.0.1, Copyright © 2005 by Digidesign, a division of Avid. All rights reserved. TimeAdjuster.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Trash.dpm 1.1.4, Copyright © 2006 iZotope, Inc. Trigger.dpm Trim.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. URS Phat C.dpm URS Phat C 1.0.0 beta 8, Copyright © 2010 Unique Recording Software, Inc. URS Saturation Native.dpm URS Saturation 2.5.0, Copyright © 2008-2009 Unique Recording Software, Inc. Ultra-Channel (Anth 2.0).dpm 1.5.1.0 (Anthology II), Copyright 1991-2009 Eventide, Inc. Vacuum.dpm 1.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. VariFi.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Voce Chorus-Vibrato.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. Voce Spin.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. WaveShell-DAE 7.1.dpm 7.1.1.5 Build 7562 XPand!.dpm 2.0.2.10105 Copyright 2009 Digidesign, A Division of Avid Technology, Inc. bombfactory BF-3A.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. bombfactory BF76.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. iZOzone4PTHook.dpm 4.0.3, Copyright © 2001-2008 iZotope, Inc. moogerfooger AD.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. moogerfooger LP.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. moogerfooger Ph.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. moogerfooger RM.dpm 8.0.0, Copyright 1991-2008 Digidesign, A Division of Avid Technology, Inc. |
Having a quick look there's a few at least out of date or incompatible!! I though you had installed all the latest version? >All plugins are the latest installers on a brand new computer< Or did you copy your old plugin folder over? Can say if this is exactly the cause of your problem!! but a really clean and up to date plugin folder is the first line of defence Suspect?... AmpliTubeLE AmpliTubeLE version 1.0.2, Copyright © 2004 by iK Multimedia. I would also check all other Amplitude stuff!!! not compatible! with 9... B4 II.dpm 2.0.4, Copyright © 2005 Native Instruments Out of date... EZdrummer.dpm © Toontrack AB 2006, Version 1.1.5 ..... (should be 1.2.1) Out of date... ...(All should be version 1.3) T-RackS Equalizer T-RackS Equalizer version 1.2.1, Copyright © 2004 by iK Multimedia. T-RackS Multiband Limiter T-RackS Multiband Limiter version 1.2.1, Copyright © 2004 by iK Multimedia. T-RackS Soft Clipper T-RackS Soft Clipper version 1.2.1, Copyright © 2004 by iK Multimedia. T-RackS Suite T-RackS Suite version 1.2.1, Copyright © 2004 by iK Multimedia. T-RackS Tube Compressor T-RackS Tube Compressor version 1.2.1, Copyright © 2004 by iK Multimedia. Chris
Thanks for your help Chris. Pretty certain i was still having this issue from day one. I have only dragged across the older T-Racks & Amplitube plugins as the new versions didn't recognize the older versions settings, when i loaded up a session.
I'll get rid of the plugs you have identified and re-post if it occurs. |
Have you tried posting in the PT9 forum? I believe they have an area set up just for PT9 now...
... but does it help the chorus? |
Kernal Panic with 6.9.2 and OS 10.4.9 | brokenbulb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-09-2007 08:15 PM |
OSX Kernal Panic | HiRaX | Pro Tools TDM Systems (Mac) | 7 | 02-07-2006 07:22 AM |
kernal panic again | seamur | Pro Tools TDM Systems (Mac) | 13 | 11-24-2004 05:35 PM |
kernal panic | seamur | Pro Tools TDM Systems (Mac) | 1 | 11-17-2004 07:35 PM |
kernal panic | spoot | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-17-2003 05:30 PM |
