problems with external clock and mbox pro
I have serious problems with external clock sync and mbox pro
my setup is: macbook pro 2.4 intel core duo PT 8.02 mbox pro apogee rosetta A/D (which is my main convertor and spdif clock) I use the rosetta as a external clock via spdif - whenever I startup protools in the morning PT switched back to internal but is not able to playback because of dae error -6085 buffer size something I have to switch back to spdif and restart and then everything works fine but its kinda annoying every morning the same procedure... pete |
Re: problems with external clock and mbox pro
Is the Rosetta powered up first? I would start by making sure the Rosetta is on before powering up the computer(maybe power the Mbox as well) so the Mbox will see the Rosetta clock as up and stable(when DIGI hardware does not detect a stable clock, it reverts to internal automatically).
Let us know if it works. I got my fingers crossed.....
ok what I did is:
- I kept the rosetta (external clock) ALWAYS on and just switched mac book pro and mbox pro off - clock didnt change back to internal but I still got error -6085 when I hit play after launching protools any other ideas what could help? Mac Book pro PT 8.0 cs2 MBOX pro Apogee Rosetta |
Are you possibly using the Mbox Pro with the power supply attached?
If so, shut everything down, disconnect the power supply, then restart and test again. If you aren't using the power supply, try shutting down, disconnecting the Mbox Pro, restarting and plugging it in after the computer boots up. Let us know if either of these fix the errors. |
so what I have to do EVERYTIME I want to use protools is startup, then get error -6085, go to hardware setup, change clock to internal and back to spdif, restart protools - like this it works as long as I only shut down the computer but keep everything powered I can startup and it works but if I switch off power I have to do the restart and reclock thing again... is this a bug? never had this problem with 7.x |
digi? anyone?
ok this is now really weird..! I dont use the apogee anymore only mbox and I still get error -6085!
I checked the answerbase but nothing seemed to help I have a 002 and a mbox pro and with the 002 I never had these problems I have now with mbox pro which I bought 2 weeks ago what could this be? |
-Jesse ___________________________________________ |
Mbox 2 Pro/Rosetta 200 - external clock problems | jlcnyc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-31-2009 07:54 PM |
Problems Bouncing to MP3 using External Clock | mjake03 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-12-2009 09:34 AM |
Venue + ProTools + External Word Clock Problems | Travis Brockway | VENUE Live Sound Systems | 5 | 03-22-2008 11:03 AM |
Clocking MBox 2 with external clock | pguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-08-2007 08:33 AM |
MBox and external word clock | GoodandEvil | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-15-2002 10:57 AM |
