Old 10-17-2005, 09:50 AM
conbreaker conbreaker is offline
Default Digi 002 with control 24
Can You use the Control 24 console with the digi 002 full console
Old 10-22-2005, 06:02 PM
Riad Riad is offline
Default Re: Digi 002 with control 24
Yup, and you get 8 more faders
www.carvelstudios.com
Old 10-23-2005, 10:27 AM
davetheone davetheone is offline
According to this link to samash.com
The digi 002 does not support control 24
http://www.samash.com/catalog/showit...RCH&GroupCode=
Old 10-23-2005, 05:28 PM
Figures it would come from SamAsh, they are almost retarded. I guess my 002 & Control|24 setup was from the magical mystical world of Digilore.
EDIT: That links to the specs for the Command 8 - different peice of hardware.
Old 10-23-2005, 06:57 PM
I am very interested in the control 24. I want to expand the system little by little. The digi 002 has grown on me and I just wanted to be sure about the control 24. I'm confused thought; which drivers do you use? Digi 002 has seperate driver. I understand the pro control 24 hooks up via ethernet; how do you use both sets of drivers and using it as one system in the same session?
This is str8 from the digidesign website
Expanding Digidesign Hardware I/O
Only Pro Tools TDM systems can be expanded with extra cards and audio interfaces
Only a single Pro Tools LE hardware system can be accessed by Pro Tools LE
While Digi 002, Digi 002 Rack, and Digi 001 Pro Tools LE systems can all be expanded using third-party A/D and D/A hardware up to 18 simultaneous I/O using the 8 ADAT light pipe connection and stereo S/PDIF connections, 2 LE systems cannot be used together on the same computer
Sam Ash.com
Digidesign - Control 24 for Pro Tools
The result of a Digidesign and Focusrite partnership, Control|24 shatters everything in its price range in terms of quality and performance. With its ergonomic control surface, 16 Focusrite Class A mic pres, surround capabilities, Ethernet connection, and compatibility with both Pro Tools TDM- and LE-based systems*, Control|24 is a quality alternative for environments that don't need the additional features or extensibility of ProControl. Control|24 transforms even the most complex sequence of functions into a series of intuitive movements, substantially enhancing the speed of working with Pro Tools.
Features include:
* 24 touch-sensitive, motorized faders
* Hands-on access to and control of Pro Tools recording, routing, mixing, and editing parameters
* 16 Focusrite Class A mic/line preamps
* Comprehensive Control Room section capable of up to 5.1 surround monitoring
* Illuminated switches for Mute, Solo, Record Arm, Channel Selects, and Automation Mode on every channel
* Dedicated EQ and Dynamics switches on every channel
* 26 scribble strips provided for system feedback
* High-resolution LED display for transport location at a glance
* Integrated submixer with 8 stereo inputs
* Touch-Sensitive automation of plug-in parameters using faders via Plug-In Flip Mode
* Connects to Pro Tools systems via high-speed Ethernet
* Cross-platform support for Mac OS and Windows systems
* Optional, custom DigiSnake Kits available for easy, organized connectivity
* Digi 002 does not support Control|24
Old 10-24-2005, 10:36 AM
DigiTechSupt's Avatar
There is no driver conflict between Control|24 and 002. Remember the C24 is a control surface/preamp/monitor section, not an interface. 002 and C24 will happily co-exist, we promise.
regards,
Avid Audio Tech Support
Support FAQ
Old 10-24-2005, 07:23 PM
Sound good. I think?
Digi 003 Control Surface Mackie Control Mode ctmusicman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-23-2008 07:23 PM
Digi 002 vs Digi 002R W\Mackie Control Universal Lance Driskell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 02-28-2006 12:41 PM
Digi 002 Rack + Control 8 or Digi 002 Full System YogiBear 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-09-2004 09:38 AM
Digi 002 Control Surface vs. Mackie Control damonmenne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-31-2003 11:58 PM
Control Surface vs. Digi 002 vs. Control 24? Calvin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 03-23-2003 12:18 AM
