Old 01-10-2018, 09:55 AM
paulhammer84 paulhammer84 is offline
Default MARKER problem
Hello all! I'm having a strange problem in pro tools 12 in which markers are not selecting... Meaning I'm going to click on a marker and it just doesn't select the marker. Anyone else know of this issue? Anyone know of any solutions?
Tried to ask Avid, but they told me to pay $100 for a support plan.
Thank you.
p
Old 01-10-2018, 11:10 AM
Cutlerbri Cutlerbri is offline
Default Re: MARKER problem
Are you trying to move or delete the marker? Are you trying to start playback from that memory location?
Brian
See profile page for system details
Old 01-22-2018, 08:20 AM
Either trying to start playback from that memory selection, or selecting from one marker to another. Basically I click on the marker and the cursor does NOT move there like it should...
Old 01-22-2018, 08:36 AM
john1192 john1192 is offline
2 things for the guy from the HOme Town of the Steinberger BAsses .. say hi to Ned at the Coffee House !!!
1) are you doing this from the Memory Locations Window or the Timeline ??
2) is timeline follows edit selection on or off ??
cheers john
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-22-2018, 02:33 PM
1) the timeline (top part of edit window)
2) "link timeline and edit selection" is turned ON
Old 01-22-2018, 02:36 PM
how about a little more info .. does this happen in a Fresh Blank Session with no audio tracks .. and just a couple markers made fresh ???
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-22-2018, 03:56 PM
Here's how I use my markers after I create them. Go to the Window drop down. Choose Memory Locations and you'll get a window of your markers on your session. Choose between the markers in the window and hit your spacebar.
Brian
Old 01-22-2018, 05:37 PM
To John - it happens in all sessions. Old sessions i created in PT 10 or even in blank sessions with brand new markers. It's especially confusing cause it seems to be inconsistent. But most of the time, they won't select.
To Cutlerbri - that's definitely a workaround, but I'd still prefer to figure out away to do it all in the edit.
Thanks!
p
Old 01-22-2018, 06:44 PM
Thanks!
p
can you PM me a session / or dropbox .. does not have to have any audio in it as you say, does not need any to have the issue - happy to test it ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-22-2018, 07:22 PM
Paulhammer, I'm still confused as to how you want to use markers. You are in the Edit Window, right? You have created markers for certain events within the session, like verse 1, verse 2, bridge, solo, etc. Correct?
You've named them, and for each one there is a yellow line that runs downward through all the tracks, right?
So at that point, why do you want to "select" them? Do you want to click on the marker up in the ruler? If that's the case, why have a marker? The point of creating markers is to easily access them while editing or mixing. So you bring the Memory Locations box down into your session in order to quickly place the cursor exactly at the point of a marker. It's not a "work around". Unless I'm really not following how you want to use markers.
Brian
Keyboard shortcut for jumping from marker to marker... shotgunndunn macOS 1 11-28-2012 07:45 AM
Warp Marker Problem shultzee13 Pro Tools M-Powered (Mac) 0 02-07-2010 09:27 AM
Trying to set bar/beat marker, tempo marker won't conform maitredebas Pro Tools M-Powered (Win) 0 07-31-2009 07:31 PM
Timeline selection end marker problem in new sessions Blaztphemer Pro Tools M-Powered (Win) 0 06-17-2008 06:23 AM
midi marker problem evs Post - Surround - Video 0 09-15-2007 10:38 AM
