  #21
Old 03-21-2018, 07:03 PM
AlexLakis AlexLakis is online now
Default Re: Reverb?
I normally use individual sends for verb on drums, meaning I will not send the entire drum bus out to the verb, but instead the individual tracks. This allows me to, for example, make the snare and toms wetter and the kick drum and overheads drier. This way just makes the most sense for me, as I like to use the same verb (aux) for multiple sources. I record mostly hard rock.
On another note, I've noticed in the past several years that a lot of DIY mixes/pre-production tracks/etc.. I hear seem to use reverb where I would use delay instead. Try delay, it has electrolytes!
  #22
Old 03-23-2018, 02:21 AM
Raoul23 Raoul23 is offline
Default Re: Reverb?
WOW WOW WOW......
I've been experimenting this week by adding more reverb than i normally do to a mix I'm working on, I've even added reverb to instruments/tracks that i never normally would. Overheads is one of them. I always struggled with my cymbals being to upfront and harsh, but if i turned them down they were just not loud enough, now i know reverb is the trick
Today i did a bounce down of the nearly completed track and played it on a few systems and WOW!! I cant believe what I've been missing. This is now bringing my track closer to a commercial sound, the track has more space, more air i cant believe how much this has changed my sound.
I'm sure i need to practice these techniques to make it even better but i'm happy what I've discovered and manage to achieve so far.
Thank you guys for all your input. All these years I've avoided using reverb because everything I've heard about when first mixing was typical amateur mistake was adding too much reverb to a track.
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
  #23
Old 03-23-2018, 05:29 AM
Default Re: Reverb?
As a corollary to this (I'm assuming we're talking about real drums here) is that the techniques being talked about will also work with vi drums. You just have to split out to multiple audio tracks the various kit pieces. I do this with BFD3.
  #24
Old 04-04-2018, 02:21 AM
Default Re: Reverb?
I definitely put most reverbs on aux tracks myself. There are a few exceptions, like when I'm trying to create an artificial set of overhead or room mics, from minimalistic drum recordings.
  #25
Old 04-16-2018, 11:18 AM
joeymakesmusic joeymakesmusic is offline
Default Re: Reverb?
I would try the Valhalla Room plugin with a short decay time (under .5s) and a vintage room
  #26
Old 04-16-2018, 01:48 PM
amagras amagras is offline
Default Re: Reverb?
If it's not too late to chime in I believe sometimes a minimal use of reverb in the snare and the toms is all some drums need, and I repeat, sometimes and some styles of music. I made this video where you can hear the idea, the explanation is at the end, I used Eventide 2016
https://youtu.be/bUsiP16BLF8
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools 2018
amagrasmusic.com
  #27
Old 04-16-2018, 01:50 PM
Default Re: Reverb?
Absolutely^^^ I never use the plugin room or ambience sounds. Using my own makes those drums sound more like me and less like the other 20,000 people with the same plugin
Asus x99, Intel i7 6800K, 32 gig DDR4, GeForce 750 Ti, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs and Midas..............................
www.capricornsoundworks.com
  #28
Old 04-16-2018, 04:02 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Reverb?
Originally Posted by Raoul23 View Post
WOW WOW WOW......
Might want to try having filters, Hi pass and Lo pass EQ before the reverb on the aux. sometimes helps to remove some of the lower frequencies going to the verb and sometimes some hi frequencies as well. helps to keep it all from getting too muddy and washed out, more dence sounding so you don't really notice its there till its gone.
Also EQ after the verb or delay to find the sweet spot for the verbs and dekays can work great.
Automation is good as well as you don't often want as much through intros and verses generally.
Chris
Producer, Engineer,
UKmastering E-Mixing & Mastering facility
www.ukmastering.com
PT10.3.7 Lion HD6 accel Magma PE6R4 Control 24 Harpertown 8-core UAD-2 Quad / SSL Duende Native. Manley Vari-Mu, Manley Massive Passive, Solid State Logic VHD, Anthony De Mario ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Reverb asef@me.com RTAS & TDM Plug-ins 4 02-24-2014 04:30 PM
Flux ircam reverb and session reverb klaukholm Buy & Sell 7 10-23-2013 12:42 PM
About to sell PCM91 in favuor of Ren Reverb-Reverb One - is this a mistake? hokuspocus Pro Tools TDM Systems (Mac) 14 04-15-2002 02:07 PM
Reverb One - Vocal Reverb advice ianmiller Tips & Tricks 2 10-28-2001 05:16 PM
About DIGI now Reverb "Reverb one" MAri Pro Tools TDM Systems (Mac) 1 07-25-2000 03:30 PM
