Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 02-09-2019, 12:52 PM
diverseradio diverseradio is offline
Default is it best to master after converted to wav or can I do it before while in session?
I'm wondering if the sound quality will differ if I master pre or post conversion to wav. Thank you for your time
Old 02-09-2019, 01:56 PM
Default Re: is it best to master after converted to wav or can I do it before while in sessio
This will likely get lots of opinions, so here's mine(and do take it as opinion):
Quality, being a relative term, is probably not the right way to look at this. First and foremost, the biggest thing that a pro mastering engineer brings to the music is, a fresh set of ears(and perspective). I have plenty of dandy mastering plugins and a very well sorted monitoring setup, yet I still prefer to NOT self-master. Why? Mostly because its very tough to be objective when you've heard the song a hundred times.
As to mastering as you mix or after, I tend to leave it till after. Why? Because I want to get the mix as "perfect"(another relative term) as I can, without mastering stuff(which can tend to make things seem polished well before they actually ARE polished).
My master track does have FabFilter ProQ 2 on it, but its only doing a hi-pass around 25Hz. Its up on a 3rd screen so I can glance at its hi-res meter and the spectral display).
I will often slap Ozone or waves L2 to push volume up for client ruffs if the client doesn't grasp the reality of listening to un-mastered mixes When I bounce the final version, the master gets no plugins if its going to a mastering house. If I am mastering, I might add that AFTER the mix is approved, but on the actual mix(saving as its own version so I always retain the final mix(as well as most of the previous mixes). But other times, I will import all the un-mastered finals into a separate mastering session, so I can compare songs side by side and make them all sound like they belong together(which means mastering each song, individually, not passing all thru the same master track and plugins).
Old 02-09-2019, 02:49 PM
thanks Dave
Old 02-09-2019, 06:10 PM
Philthy Philthy is offline
Assuming you keep your sample rate and bit depth the same when you print to WAV, it should make no difference. WAV is uncompressed, meaning no loss of quality.
Phil Mann
Silk City Music Factory - CT Recording Studio
Old 02-09-2019, 07:51 PM
JFreak's Avatar
JFreak JFreak is offline
Technical quality is 100% there if your wav file only contains ones and zeros. The sample gets distorted if your file has a two somewhere.
Seriously, joking aside, as said, quality is subjective. Which is why you should mix first, bounce the final mix, then send it to someone else for mastering. Unless you can replace your ears with a fresh pair, remove your memories regarding the mixed stuff, and begin mastering in another room.
Point being you are more objective if you haven't heard the mixes you master before, and a fresh set of ears and a different sounding room gives you 2nd opinion, which is crucial unless you mix in a perfect room.
Janne
Old 02-09-2019, 10:07 PM
cwsand's Avatar
cwsand cwsand is offline
When I first read this, I was thinking about converting to a lower sample rate or bit rate which would mean a loss in audio quality (though you may not be able to hear a difference). Plus, if you convert to 16-bit from a higher bitrate, you need to dither. I would think you'd want deliver your mix to mastering at the sample and bit rates your session is in, and let the mastering engineer do the conversion and dither, though both are simple enough to do in Pro Tools.
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2019.10
Old 02-09-2019, 11:54 PM
wwittman wwittman is offline
Originally Posted by cwsand View Post
... I would think you'd want deliver your mix to mastering at the sample and bit rates your session is in, and let the mastering engineer do the conversion and dither....
That’s of course right, if you’re sending your tracks to a professional to be mastered.
But the original poster implies he was “mastering’ himself and wanted to know ‘when’?
No?
I think the important question would be what exactly he MEANS by “mastering” in this context.
Too many people just mean “make it loud”.
William Wittman
Producer/Engineer
(Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!)
Old 02-10-2019, 03:21 AM
innesireinar innesireinar is offline
There is no difference, as long as your system can handle mastering plugins into the session, given that mastering plugins are usually very hungry. If you are going to master your stuff by yourself, leave at least a couple of days from the mix process to the mastering for refreshing your ears on that track.
Avid HDX - PTHD 11.3.2 on OSX 10.10.5 - PT Ultimate 2019.6 on OSX 10.13.6 (II partition) - Cubase Pro 10 - Avid HD I/O 16x16 analog
Mac Pro 5.1 quadcore 2.8 16GB Ram
Old 02-10-2019, 08:07 AM
GTBannah GTBannah is offline
Charles Dye belongs to the school of thought that says, "Mix It Like A Record".
You mix with the compressor, limiter, mastering eq etc ALL IN PLACE.
https://kagimedia.com/mix-it-like-a-record
I think it's a personal thing. let your experience and your ears be your guide.
Derrkins
GuyBarTola
PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!!
Old 02-10-2019, 09:45 AM
JFreak's Avatar
Yea cannot diasgree with that. But while you mix it like a record shouldn't limit you to the "mixing" decisions but instead bypass all conventional (*) dyn/eq from the master buss before bouncing and let the ME do the same decisions with better gear and fresh ears.
*) meaning dyn/eq that is not "the" sound of your song but more like "tweaks"
Janne
Session Notes - TDM DSP Plugs converted to Native psmworld Pro Tools HDX & HD Native Systems (Mac) 3 01-07-2015 07:17 AM
PT Session File Converted Itself to Older Version? MetalGarret Pro Tools 10 2 10-19-2014 11:08 AM
16 bit session converted to 24 bit - what happens? Ken P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-03-2005 12:16 AM
omf files converted to pro tools session on pc?? jsmooth226 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-08-2002 09:12 AM
