Buying used pc
I can pick up a used gaming pc with these parts for around 400$ i7 6700k MSI z170A 16 Gb ram (only 1200 MHz) Nvidia Geforce gtx 970 Will it be a significant step up from my i7 980x pc?
Antelope Orion Studio 2017, UA 4-710, Presonus digimax FS, Sony DMX r100 |
Re: Buying used pc
I'm assuming you mean Pro Tools performance.
If you are already using SSD drives in your current system, then no, I don't think you will see a drastic improvement. Overall, the new system will be more responsive, and programs will load faster, but those old processors were pretty powerful and once PT is open and running, I don't think you will see much difference. If you are running into issues running your sessions, let us know a bit more about your full set up and how you are using PT and we can try to guide you to a better system. |
Re: Buying used pc
i7 4770K, 4th generation quad core, on an ASUS Z87-Pro motherboard. Just did the last upgrade I can unless I upgrade the video card: Samsung 970 Plus NVMe drives and from 16 to 32 GB of RAM. Computer is 7 years old and should last another number of years.
I don't stress the system very much as normally I'm just recording my voice for projects, but I also do described video, so have video, sound track, plug-ins and a producer's track so they can remote direct, at 64 buffer. I've also mixed a small movie - all with some Waves plug-ins and at 64 buffer when I had spinner hard drives and 16 GB of RAM. As Will mentioned, let us know what you have now - a Sandra report would be good - and let us know what issues you're having and your typical session and its requirements.
Re: Buying used pc
I was just wondering if the sixt gen cpu would be better than the first gen really.
I ended up returning a new pc this summer. A i9 10900x. Expensive... almost 3000$... of course better than my old one, but I felt it could not justify the price... But if I get better performance for 400$ that would be something to think about.
Re: Buying used pc
You should be able to bag a used HP z820 off of eBay. I had one that was dual 6 core XEON's at 3.5GHz, 64GB of RAM, nVidia graphics and a 500GB SSD loaded with Windows 10 Pro for $1100, shipped to my door. Tossed in my audio and samples drives and my HDN card and it ran like a train I did need to add a USB3 card(for more ports) and a Behringer USB>SPDIF box for Windows sounds and I swapped the graphics for a card I had that would drive 3 screens.
Re: Buying used pc
I don't think you'll see a significant difference - the exception being if you routinely run long chains of CPU-intensive plugins that saturate one of the cores - the single core performance improvement between the 2 CPUs you mention is significant (see below). I use PassMark for doing CPU comparisons - PassMark corelates reasonably well with DAWBench (a good Audio-specific Benchmark). In the images attached you can see that the overall PassMark is not that different between the 2 CPUs (980x vs. 6700K). I personally waited to upgrade from a 3700K until I could get an 8700K because there was no compelling reason. The 10900K has pretty good performance improvements, BUT you would have to be silly to buy a new Intel CPU right now - the M1 and AMD 5950 make Intel's top end look sad - one for core count and single core performance, and the other for power efficiency. Intel must have an interesting response soon. Competition is good. Hope that helps. YMMV ejinbc |
Re: Buying used pc
According to this, you'd theoretically pick up about 10%: https://cpu.userbenchmark.com/Compar...0K/m3336vs3502 Wait to upgrade if you can. The CPU battles are hot right now, thanks to Apple and AMD. I'm currently running ProTools on an i7-980x with a slight OC to 3.9Ghz. It's working well, but it's not exactly a modern monster! This CPU (or similar) would give you about 34% more juice: https://cpu.userbenchmark.com/Compar...m3336vsm929964
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume Last edited by EGS; 12-08-2020 at 06:38 PM. |
Re: Buying used pc
The specs look good. The price is all that matters now.
Re: Buying used pc
From my own experience:
Moving from a X58/980X system to an X99/6800K system was a pretty serious jump in power. The problem for me was poor stability. I fought with the X99 rig for several months before I bought the HP z820, which was solid as a rock. If you're still bent on the 6700 rig, the motherboard/chipset can make or break things. To me; that motherboard is a giant unknown
Re: Buying used pc
Interesting.. The HP Z820 is from 2009?
There is a computerstore here in Norway trying to sell one for 3500$.... I offered 500, so we sill see :)
Buying PT 10 | djmichael.london | macOS | 7 | 02-18-2013 02:15 PM |
Buying a Mac | Rizzle | Pro Tools M-Powered (Mac) | 9 | 10-12-2008 01:13 AM |
buying a new mac | kds | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 10-21-2004 04:53 PM |
HELP! I am buying a Dell Laptop with intent on buying a DIGI 001 as well | xian$ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-18-2003 11:53 AM |
buying a used 001 | JFogarty | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-17-2002 12:13 AM |
