no midi patch select in mix window?
Any ideas? I am running PT 8.0.1. I see the midi patch select button in the edit window on each channel, but do not see it at the bottom of the mix window channel strips? I believe it should be there, thought it mentioned it in the user guide...I can select different midi patches this way in the edit window but it would be nice to do the same in the mix window...thanks...
Re: no midi patch select in mix window?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
hi Flommer...it's actually the patch select icon that used to be at the bottom of the channel strip in the mix window under PT 7...I do not see it in either a midi track or an instrument track in the mix window...I'm not in front of my system now, but do not remember seeing it in instrument view in the mix window either...will confirm tonight...freaking me out...
Actually, in the PT 8 reference manual, it is showing the patch select icon on page 157, for both midi and instrument tracks...it just doesnt show up on my system? perplexed...
It should be there for Midi tracks as well. I painfully went through the trouble of making a .midnam file for my MR-61 with the expansion cards
and a couple other outboard synths/ drum machines. Yes... I am a music geek. I should get out more.
2012 Mac Mini i7 2.6Ghz, 16GB RAM, 250GB SSD, OS 10.8.4, 003R, PT10.3.4, Midi I/O and late 08 15" Macbook Pro 2.4GHz, 4GB RAM, OS 10.8.4, Mbox2, PT10.3.4 |
I finally got around to checking...
The button is right above the track names Inst tracks and MIDI
OT question: Did you find a pdf or something you can copy/paste from or did you type in every patch name??
For the MR-61, I used the MR rack midnam as a template and added the expansion boards patches manually. It is amazing what you can get done with some good music and caffeine. I emailed Novation about my Supernova II and they were nice enough to send my the patch lists in simple text. That sort of made up for the heavily advertised but never produced adat card for my Supernova II.
Flommer...thanks, I found the answer. Ridiculous of course...I had narrow mix window view selected...when viewing the wider view, it shows up...thanks for your help...
Axiom Pro 61 Patch Select | Speeder | Virtual Instruments | 2 | 09-06-2009 08:38 AM |
Patch select problems | sevenson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-03-2009 07:04 AM |
Progamming sound module into midi patch select | positive crew | Tips & Tricks | 3 | 01-29-2006 09:31 AM |
CRASH when i try to select MIDI patch | minister | Pro Tools TDM Systems (Mac) | 3 | 08-09-2005 11:02 AM |
Midi Program Button (Patch Select Dialog Box) | cc1 | Pro Tools TDM Systems (Mac) | 0 | 05-22-2004 10:13 PM |
