#61
Re: Shift + fader sets level to 0db
The release notes for v3.3 claim this has now been fixed. I haven't yet updated myself...
Can anyone confirm Shift + fader actually works now? (according to user robertg, it does not) |
#62
Re: Eucon 3.3 and again, the lack of requested features.
#63
Just to give you a hint - with version 2.7.1 it was working fine Just read the code, which was written at that time and you will satisfy many of your customers and users. Cheers
**************************************** ALSTUDIOS REGENSDORF SWITZERLAND [email protected] https://sites.google.com/site/alrecordingstudio/ 1pc AVID Artist Control and 1pc Euphonix MC Mix Win11 64Bit, Cubase Pro 12.0.52 **************************************** |
#64
Which surfaces are you seeing the issue with SHIFT + Fader = 0db? Does it occur on a new session with one track? Its working on our end and LDS mentioned its working as well. If there is a scenario we missed where this is still a bug we'd like to fix it asap. Let me know. Thanks,
Kyle Splittgerber Senior Principal Product Designer Avid Berkeley, CA |
#65
I updated this morning and it doesn't work, although yes, I get slightly less intermittent results if I tap the fader cap SUPER FAST. It should snap to 0 no matter what you're doing to the fader, so long as you have the button depressed.
I don't understand how this keeps being missed. |
#66
"We also managed to squeeze in the following fixes including the much requested fix for SHIFT + Fader touch not resetting to 0db! What’s Fixed • Shift + Fader touch does not set fader to 0dB (EUCON-2883) " |
#67
I'm sorry to hear this is still not working, guys. We are looking into it asap.
For those of you experiencing this, please let us know which surfaces (Artist Mix, Artist Control, or S3) are affected. Thanks!
#68
We just looked at this with Artist Control and Artist Mix and if you hold SHIFT and tap the fader cap for a split-second (don't tap + hold) it will reset to 0 db consistently. Can you guys check to see if you see the same?
Thanks.
#69
Works well in Cubase 8.0.2.. No issues...
Cubase 10.5 Intel i7 5960 16GB, Windows 10 64 Transport/Control/Mix x 4 |
#70
Sometimes the fader will reset consistently, and then other times I have to tap the fader two, or three times to get it to work! It doesn't seem to be consistently responsive with the amount of pressure on the fader cap either... I try to tap the fader the same way after a successful return to zero, but sometimes it works... and sometimes it doesn't! What's interesting is that I never had a problem with the Artist Control... It was only the Artist Mix that didn't reset to zero dB as expected! The Artist Control would immediately respond, and quickly reset to 0dB when Shift + Fader was applied. The Artist Mix would not respond at all to the same command! Now, both the Artist Control, and the Artist Mix seem to respond more slowly to the Shift + Fader = 0dB command! (maybe .5 to .75 of a second). So, I guess an argument could be made that the more sluggish response is less wear and tear on the fader mechanism, and the Mix does respond to the Shift + Fader command more often than not... which is better than not responding at all! So, thanks guys... your efforts are appreciated! Al
Computer Asus P9X79 Deluxe | Intel i7 3930k | 32 Gig Ram | Intel 520 SSD's | 2T Caviar Black Software Win 7 Ultimate (64bit) | Cubase Pro 9.5.41 (64bit) | WaveLab 9.5.25 (64bit) | HALion 6 (64bit) Hardware RME FireFace's UFX / 800 | MOTU MTP AV USB | Avid Artist Series: Control, Mix, and Transport | EuControl ver. 18.3 |
Shift+fader touch= wtf!?!?! | C52382P | Artist Series | 3 | 04-23-2015 02:51 AM |
Eucon 3.1 bug with McMix: Shift-Fader doesn't work | DhyanMikael | Artist Series | 5 | 12-24-2013 04:50 AM |
VCA Fader Level | Jstil | Pro Tools TDM Systems (Mac) | 7 | 04-28-2011 12:21 PM |
Fader bank shift changes on screen location | The Tonic Room | ICON & C|24 | 3 | 07-29-2008 10:10 AM |
"Shift" command not affecting VCA fader automation | Matt Chan | Post - Surround - Video | 2 | 12-15-2006 06:24 PM |
