Digi/PTLE doesn't "see" MC Control/Mix
I just got this yesterday from Sweetwater- followed the install- under System Prefs .-> Euphonix
I keep geying the error message "ProTools is unable to communicate with the HUI..;.etc I'm using the ethernet cables that came with the MC Control and Mix and the very same ethernet cable that was used with my Control 24 I'm only getting faders 5 - 8 to operate on the MC Mix... and banking sees the first 4 tracks .... or the last 4... nothing in between... The MC control did come on for a brief minute and I had 8 tracks going, but then it stopped... the touchscreen does seem to get some response moving from fader to fader... but nothing much else I'm using a Netgear 5 port 10/100 fast Ethernet switch (also from Sweetwater with the purchase of the to surfaces)... a lot of flickering... which I'm guessing like most hubs/switches is communication??? PPC G5, 2.3 dual, 5 GB RAM,10.5.8, Digi 002R/ Presonus D8, PTLE the last cs for 8.0/PPC
Stainless - G5 2.3x2, 5 GB RAM, 1.5TB, OSX 10.5.x and 8.0 002R/D8, MC Control/MC Mix, etc, etc, etc |
Re: Digi/PTLE doesn't "see" MC Control/Mix
I know nothing about the operation of the Artist series HUI emulation. But, I do know networking. If you are close to a Target/Walmart/Best Buy I would try to pick up another hub just to see if that could be the issue. If it doesn't fix the problem return it.
it appears to be an addressing issue, plugging the MC directly to the computer (no hub) ... same results
Did you try the steps in this FAQ on the Euphonix support site?
How do I connect directly to a Mac? Quote:
Euphonix Downloads Also on the downloads page: EuCon Application Setup Guide (How to setup connection of MC Control, MC Mix and MC Transport to different applications) Setting up EuCon to Control Pro Tools Before proceeding, make sure you have installed and are running EuControl as described in the Installation section of your Quickstart or User Guides.
Administrator Avid Pro Audio Community |
The Euphonix MC Artists are lovely in Logic...you can get them to work in PT but you will see how Digi crippled them to the HUI (only four letters per scribble strip, etc.) when they were still viewed as enemy.
One of the most annoying things is I can't get "jog" functionality via the Mc Control like I can in Logic (one of the most useful things). I only get scrub/shuttle and I have to use modifier/scroll wheel on the mouse to jog and zoom in PT still. I really wanted to buy one or two MC Mixes to add to the MC Control but that purchase was put off when divA snatched Euphonix. I will have to wait to see what gets crippled and what gets de-crippled accordingly before making any further purchases. In this article Gahagan seems to say all the right things (Requires Flash): http://www.nxtbook.com/nxtbooks/newb...ia_201005/#/20 Can a company resist its old hostile impulses though? Maybe loss of power de-corrupts. |
I have it working... now comes the learning curve for the soft buttons/keys, but I'm generally pleased. having come from a Control 24 where buttons didn't work, I was aware of the limitations of HUI (for once, eyes wide open)
Still working at getting it to work with Reaper (which the Cuckos forum indicates it does well)... and I plan on adding Logic so I can work multiple projects without ..... hindrance I am very hopeful that Digi/Avid/Euphonix will not overlook the fact that there are a GREAT many of us still on PPC, when they better integrate the product lines to consummate the marriage. I believe this will both maintain loyalty as well as increase product appeal... i find it somewhat ironic that Protools is that last platform listed in the Application set-up PDF (and the only HUI)
So I would keep expectations at zero for Eucon PPC support moving forward. |
Oh and here's something rather interesting...
http://www.youtube.com/watch?v=wChJEr-y5nM You can put your DAW mixer window and plugins direct onto an iPad without any audio company's involvement: Air Display is just $9 general purpose software that turns your iPad into a touchscreen display for your Mac. The performance is a bit sluggish and it isn't multi-touch, but essentially things like the MC Control can be disintermediated by cheap general purpose tech like that. I would like to try it as it stands, the whole package would be half the price of an MC Mix and work with any software whether divA tried to quash it or not! (Euphonix sold at the right time!) |
up and running, PT works... (now to learn all the various features that DO work)- I think it's also set-up for Reaper, but haven't had time to run a test session
There's must be a correct way to start things Computer.... wait till after the desktop is up before powering up the Control and Mix? ( I get the error about the static IP configuration... has changed, so i power the Control/Mix down power down the hub, wait a few, power up the hub, the the Control/Mix and then it seems to work fine or there's still something not to it's liking in the Internal Ethernet 2 set-up I'm on the PPC for another year so I can get full moneys worth/depreciation out of it... maybe the price for the dual quad will come down a bit... or the next generation will get introduced and i can get in at the beginning of the wave... instead of nearing the end of the production run-
If Pro Tools throws this error up, it means one of two things: 1. The Euphonix MIDI ports are stale in AMS. Re-assign your HUIs in Pro Tools. Also check the Euphonix MIDI device in AMS. If it is DIM then more steps could be involved. There is an FAQ about this here: http://www.euphonix.com/artist/suppo....php?detail=32 2. Pro Tools is no longer in the Euphonix System Preference panel. This can happen if you have bad permission, or you are not an Administrator when you add the application. http://www.euphonix.com/artist/suppo....php?detail=27 |
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
Cant find Licence # in "My Digi" for "Reason" | jefflennan | MIDI | 1 | 09-08-2009 12:32 PM |
Digi: PTLE 5.1.1 "Out of Stock"??? | dans | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-14-2003 01:35 PM |
"Digi Control" Digi-001 control surface | nukmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-30-2002 12:33 AM |
