Joystick
Very Nice! Love this promisse. Be able to XY control parameters will be very nice!
Love it.
Ricardo Cutz Re-recording mixer/sound editor supervisor. Http://106db.com.br ----- |
Re: Joystick
Glad to hear you are excited… Here's my blog post with a bit more info:
http://www.avidblogs.com/nab-2015-avid-pro-mixing-news/
Tom Graham Avid Audio Marketing Pro Audio and Mixing [email protected] Check out our Pro Mixing Webinars : http://www.avid.com/US/resources/pro-mixing-webinars Avid Pro Mixing Blog: http://www.avidblogs.com/promixing/ |
Re: Joystick
was there where I found about it in the first time. ;-)
Re: Joystick
Let me tell you a story. I sat with an Avid rep (in our dealer's demo room) almost exactly 45 days ago, just before purchasing an M10-24. We talked about how valuable a hardware panner would be to us. The rep told us, simply and clearly, that the touchscreen was our only Avid solution with nothing else in the works that he'd heard of. So we filled out our 4 buckets, which is the maximum number of M10 modules.
I would request that a panner module be allowed to be added as a sidecar to our M10-24, in addition to the modules we already have not instead of one of them. Otherwise, a JLCooper stick will continue to serve here. Last edited by Postman; 04-13-2015 at 09:13 AM. Reason: not 60 days but 45, our demo was on Feb 25 |
Re: Joystick
so you have to remove a fader bank or other module to fit the joystick in? No way to add it to the master module?
Re: Joystick
Having put together a few S6 consoles, I see no reason why, with a little ingenuity, why you wouldn't be able to build a little side car for the Joysticks. Assuming you have a port open on the router and can extend power to it.
Randall Quote:
Randall Smith Audio Editor/Mixer Starz Entertainment Group Denver, CO |
Re: Joystick
Re: Joystick
My installation manual for the M10 says its limited to running 10 modules total. That would be 9 modules for the fader/knob/process, and the 10th is the automation module. Full.
Postman- where did you hear about 11 modules support? My understanding was M10 = 10 modules max and M40 = 40 modules max |
Re: Joystick
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
Re: Joystick
Now that we have this option of Joystick pannel - if it will work as s6 piece, and not as midi joystick, like JL Cooper ones, I do believe that Avid should revise the S6 m10 maximum config to allow a 24 faders, with all 3 processing modules, 3 processing knobs and a joystick model! It won't hurt any bussiness model...
Surround Joystick Options | BroomPole | Post - Surround - Video | 2 | 04-09-2010 12:38 PM |
Joystick recommendations? | Eric R. Fischer | Post - Surround - Video | 10 | 06-20-2005 10:41 PM |
Joystick won't work. | adesound | ProControl, Control|24, Command|8 | 1 | 05-21-2005 03:21 PM |
Joystick for Mix system | ripple FX | Post - Surround - Video | 4 | 01-04-2003 03:33 PM |
Joystick option- | cmaynes | ProControl, Control|24, Command|8 | 0 | 08-11-2002 09:21 AM |
