Recording Flamenco Guitar
Hi guys,
I am recording a friend playing flamenco guitar. I manage it pretty good, but in every piece there are two or three (peak loudness) chords I just cannot manage. I am doing parallel compression, sending all to Aux 1 with EQ only. I envelope the peak chords there a little, but still get the red signal on that Aux. I send to Aux 2 with reverb, and then to the master fader. In the end there seem to be no clips, but I fear the clipping on Aux 1 might have some repercussions. If I do more enveloping on these chords, it doesn't sound realistic. Any ideas? Thx |
Re: Recording Flamenco Guitar
Parallel compression won't really do anything to tame the peaks.
I would use some gentle compression to bring it in check. If you'd prefer to keep the dynamics as they are, use a limiter to catch the peaks. Sent from my iPhone using Tapatalk |
Hi Sardi, the player's condition was that all the compression there may be is the parallel compression (he wants that sound).
Acoustic people generally seem to bear grudge towards compressor/limiter. |
You might try backing your mics out a bit. Or you just could tell the player to go practice a bit and come back when he's got his dynamics under control...
I7-4930K, X79-Deluxe, 2133 32 GB, GT640, 512GB 860 Pro, 1TB Evo, WDB 2TB X2, Win 10 Pro, PT Ultimate 2020.12 Studio One 5 Pro, REAPER 6 RME, Daking, Heritage, ISA, Sytek |
Some other things to try;
1-if the same part is played elsewhere, grab a clean clip and paste over the squeaky section 2-highlight just the squeak, call up EQ III in Audiosuite and click the audition button, add a very narrow boost, sweep it until the squeak is its loudest, cut that frequency by 3-4db and render. This can be repeated(keep the EQ plugin up on the screen to hold the setting). Doing this might allow you to tame it enough without removing it(a little squeak can sound natural) 3-try a de-esser
Thx for the elaborate answer. I'll give a try to all the solutions tomorrow.
Just to make clear, there is no clipping whatsoever in the original recording. I just get it on the Aux1 with EQ. On Aux 2 and the master fader, and the bounced audio, everything seems fine. I would even leave it as is, but have no experience with flamenco recordings, and fear there might be some artefacts audible in the course of many format conversions, compressions etc. Thx again! Quote:
You can try automation too !
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
Uh? That thing is a part of that style, and using proper mic technique things should be under control at all times. In case the stuff has already been recorded, just use a limiter that only catches that one peak. It's just as same as volume automation, but easier to do.
Hi Not sure of your exact parallel compression signal flow but I believe you can introduce phase shifting if EQing either the compressed or uncompressed signal and then recombining.
Simon2065 Pro Tools Ultimate 2023.12 Win 10 Pro 22H2 Gigabyte GA-Z270 i7-7700K 32GB Ram UAD Apollo 8 |
I can pretty much say with absolute certainty, that the guitarist will not hear the effect of adding a limiter to catch the peaks.
He doesn't even need to know. Just put it in the chain and set the output to be hair below zero. Done and move one. Sent from my iPhone using Tapatalk |
Recording Guitar | Frustrated (no audio on track after recording) | Aftershock64 | Pro Tools | Intro Discussion | 6 | 08-04-2016 10:03 AM |
Recording guitar direct + guitar cab | TDub | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 07-09-2010 02:21 PM |
Nuevo Flamenco video "Yo quiero mas" Check it out! | Antonio Sage | General Discussion | 0 | 06-02-2007 10:00 PM |
pair of neumann km 184's for flamenco guitar? | MartinC | Pro Tools TDM Systems (Mac) | 6 | 04-03-2003 05:14 PM |
Flamenco guitar 's Dynamics... How Should I record it? | GuitarEasley | General Discussion | 13 | 11-17-2001 12:00 AM |
