Old 08-15-2020, 04:09 AM
crizdee's Avatar
crizdee crizdee is offline
Default Could a Graphics Card cause plugins to crash opening the GUI's
I recently put a new graphics card in my MacPro Mountain Lion Pro Tools 10, GeFofce GTX 780. all seemed well at first but now i'm building a large mix im getting issues with opening GUI's on some plugins, it takes a while for the GUI's to open and often just causes a crash. Mostly with UAD plugins but some others as well.
From what i can find the GTX780 doesn't have the drivers in Mountain Lion. the last was the GTX 680 to be fully compatible.
Everything else works fine with the 780 and running 4 monitors with no problems, its just some plugins are having this GUI opening issue. the crash logs do mention graphics and quartzcore.
Uninstalled reinstalled and trashed all prefs for PT and UAD
Never seen much about GPU's causing problems? but i guess its possible!
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-15-2020, 09:44 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Could a Graphics Card cause plugins to crash opening the GUI's
If it uses 680 drivers there may be a problem
Janne
Old 08-15-2020, 01:35 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Web drivers
Just checking on versions
http://www.macvidcards.com/drivers.html
HDN/iMac graphics weirdness and crash Bookerv12 Pro Tools HDX & HD Native Systems (Mac) 2 02-06-2018 10:35 AM
EMI Noise: Graphics card to HD Native card jacknprewitt Pro Tools HDX & HD Native Systems (Mac) 0 10-19-2013 09:02 PM
HD Native Card Possibly Fried My Graphics Card witrelo Pro Tools HDX & HD Native Systems (Mac) 1 09-14-2011 11:46 AM
little graphics oddness when opening UAD plugs crizdee Pro Tools TDM Systems (Mac) 1 12-24-2009 08:44 PM
digi init crash-move graphics card? DigiTechSupt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-24-2000 12:39 AM
