Old 09-14-2012, 10:38 AM
redmount redmount is offline
Default 16x16 Analog HD I/O only syncs @ 48/96 & 192khZ
Hello,
My setup :
Mac Pro Quad core Xeon
OS 10.6.8
PT HD 10.3
PT HD2
Digidesign 96 IO (primary port) connected to the accel card
Avid HD I/O 16x16 analog (primary port) connected to the core card
Loop sync cables In -> Out and Out -> In
Digitest runs fine.
Here is the deal :
I cannot get the HD I/O 16X16 analog to be Loop Master sync at 44.1kHz - 88.2kHz ! But locks fine at 48kHz - 96 kHz...
Everything is fine at every rates when the 96 IO is Loop Master sync.
(Problem remains the same with 96 IO on Core and HD I/O on Accel card)
Any clue ? Is there an incompatibility between those
Thank you.
Raphael.
Old 09-16-2012, 02:14 PM
the dude's Avatar
the dude the dude is offline
Default Re: 16x16 Analog HD I/O only syncs @ 48/96 & 192khZ
Core card > digilink to 192 HD primary port
Accel card > digilink to 96 IO primary port
Loop sync out 192. > Loop sync in 96IO > Loop sync out 96IO > Loop sync in 192
OR
Core card > digilink to 192 HD primary port > expansion port digilink to 96 IO primary port
Use the "Identify" function in hardware setup to confirm the order is same as described
http://www.studio-techservices.com
าำ
studio.tech@yahoo.comm
Mitch Berger Tech Services
We service ALL Avid products no Problem
HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything
ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around
inquiry using link above
Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear
Old 09-16-2012, 02:23 PM
Hello Dude,
Yes, definitely Dude. The first option is mine... Except I have a Hd I/O 16x16analog instead of a 192 I/o.
That's why I guess this sync issue is not supposed to happen.
Old 09-16-2012, 10:43 PM
phatbeatstudio phatbeatstudio is offline
Originally Posted by redmount View Post
Hello,
Raphael.
Why are they not digi linked together instead of each on it own card.
Shouldn't make any difference but with only 24 i/o they should be on the same card. Or is TDM only 16 i/o per card .
Old 09-17-2012, 12:40 AM
Thanks Phatbeatstudio,
I will need to get a mini digilink adaptator to link them together via expansion port...I'll try this.
In the meantime, I still wonder if there is a known problem with that kind of configuration.
Old 09-18-2012, 02:15 AM
the dude's Avatar
Hd I/O 16x16analog and the 192 I/o.
Are absolutly the same with the respect to your issue
And it would rule out a configuration problem, as well as the fact that this is only a problem With your system and is endemic to yours
าำ
Avid HD I/O 16x16 Analog Compatibility Question Kam Lion Pro Tools 11 1 11-17-2013 10:57 PM
Avid HD I/O 16x16 Analog Jantzen Buy & Sell 0 10-03-2013 10:11 AM
HD 16X16 analog . circle light is always green even with computer off P,B,S Pro Tools TDM Systems (Mac) 2 12-27-2012 10:35 AM
FA:Avid HD IO 16x16 Analog - MINTY FRESH!!! Biggreen Buy & Sell 0 08-18-2012 07:24 PM
HD I/O 16x16 Analog maxx.monopoli macOS 5 02-17-2012 10:19 AM
