Old 03-25-2010, 11:18 AM
redmount redmount is offline
Default Structure : the path to EXS samples
Hello,
I would like to know how to make Structure v1.1 find every samples for every EXS instruments I am trying to load.
Sometimes the "Spotlight" option works, sometimes it does not.
Is there a way to reconnect it all ?
Thank you.
Old 03-25-2010, 05:02 PM
relaxo relaxo is offline
Default Re: Structure : the path to EXS samples
Redmatica's EXS Manager Pro will link your exs instruments to there samples. GREAT way to spend $100. Works perfectly.
Old 03-25-2010, 11:57 PM
And then Structure will open each and every EXS instruments ? No need to "Spotlight" anymore ?
Old 03-27-2010, 01:30 AM
songman songman is offline
I have the entire Vienna Symphonic library in EXS format and did the following. I put the samples on one of my internal harddisks reserved for samples. I put the sampler instruments in Applications/Digidesign/Structure. Then I went to Structure, in the setup/content I gave the path where the samples are, in browser I went to where the sampler instruments are and added each and every folder to favorites by clicking on the + sign. Then I went to see if things worked out: in patch all folders with the instruments were there, when I called up an instrument a few times I was asked for the path where the samples were, after doing this a few times everything seems to be hunky-dory. I noted also that Users/yourhome/shared/library/application support/digidesign/air/structure/favorites is were all the favorites are listed (with aliases).
Good luck! Structure works like a charm now!
Old 03-28-2010, 03:16 AM
Done, I got Exs Manager Pro, everything is fine.
One more thing : Every Exs instrument I load into Structure are including a Metadata Part named "Meta_@@Rating::". A red exclamation mark appears the same way it does when a sample hasn't been found.
I tried the EXS Manager "delete all Metadatas" but no effect once in Structure.
Any idea.
Thanks.
Samples for Structure mmcl Virtual Instruments 3 06-05-2013 08:07 PM
Structure Horn samples? JazzyJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-30-2012 04:41 PM
Other Samples with Structure? pguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-16-2009 09:22 AM
Structure LE upgrade path??? scottedog Virtual Instruments 22 10-10-2007 08:47 AM
Structure / Samplecell upgrade path ? POLL ! Aquarius Pro Tools TDM Systems (Mac) 4 01-19-2007 03:02 PM
