Old 12-18-2009, 04:00 AM
innesireinar innesireinar is offline
Default A Q About The Midi Event List Window
Is it possible to set this as floating window (like the transport)?
If no, Digi could you put an option for this?
I use to open this window when working on the midi editor for viewing note parameters, but every time I do something on the midi editor the Midi Event window goes in background, very annoying.
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2020.5 - Cubase Pro 10
Mac Pro 5.1 quadcore 2.8 16GB Ram - Mac OS 10.13.6
Old 12-18-2009, 03:37 PM
Default Re: A Q About The Midi Event List Window
Agreed. I'd personally like to see the MIDI Event List stay in front as a floating window too.
filosofem
Old 03-05-2010, 05:26 AM
redmount redmount is offline
Is there a way to open any window as floating windows ?
Old 03-05-2010, 02:12 PM
Window Configurations.
Aaron Mulqueen - 001 HD Native
Old 03-05-2010, 03:04 PM
Doesn't make a window as float... just organizing. Am I wrong ?
Old 03-05-2010, 03:22 PM
I wouldn't say organized but you are correct.
Old 03-05-2010, 11:55 PM
crizdee's Avatar
crizdee crizdee is offline
The only way is to have the midi event list outside of the mix or edit window! whilst your using it just pull the mix or edit windows in a bit and place it just outside.
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-06-2010, 12:37 AM
Don't you think it could be handy to have a choice between floating window or not ? whathever the window you wish to open.
Old 03-06-2010, 09:47 AM
crizdee's Avatar
Yes definitely!! don't know why it doesn't as the midi real time window and midi operations window stays in front ok?
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-06-2010, 09:51 AM
audiogeekzine audiogeekzine is offline
I agree with the above, but I must admit I don't know what the event list would be used for on a regular basis.
@theaudiogeek
| www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com |
Anyway to keep MIDI Event List window up front? Bambison Pro Tools TDM Systems (Mac) 1 08-25-2008 04:06 AM
MIDI Event List overflows on the left side of PT's window Fastudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-13-2008 03:08 PM
Midi Event List Jel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 01-23-2007 11:07 PM
Event List as float window ? jeff caldwell71 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-14-2003 11:50 PM
MIDI event list. Where is it? yuterri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-07-2002 12:16 AM
