Old 08-02-2016, 07:43 PM
aftermid aftermid is offline
Default Omni HD
OK,
So today I noticed that Channel one on the omni mic input is dead or putting out a very low output. Channel two is fine. Channel one line and inst works fine, but not mic.
Things tried:
Reset Omni
Tried input one in back of Omni.
Checked all hardware settings.
Same mic and cable tried on Ch 2, no problems.
The channel is not completely dead. Cracking up input one will record a very faint faraway signal. So there is some low very low level signal getting in.
Anything you might suggest I should try or is Channel one Mic pre going bad? Thanks for the help.
Old 08-02-2016, 07:47 PM
Default Re: Omni HD
What Mic are you using? Same exact one in each case? If a condenser make sure the phantom power on the problem channel is OK/try a dynamic mic as a test.
Old 08-02-2016, 09:47 PM
Default Re: Omni HD
yeah, tried same mic and cable on both inputs. A dynamic mic doesn't work on channel one either.
Old 08-02-2016, 09:49 PM
Default Re: Omni HD
The first mic used was a condenser mic. Phantom power seems to be ok. Afterwards, I tried the dynamic mic to rule out the condenser mic being bad and/or phantom power.
Old 08-02-2016, 09:56 PM
Southsidemusic's Avatar
Southsidemusic Southsidemusic is online now
Default Re: Omni HD
This has happened to a few others and is not something you can fix at home.
First off you have the "pad" button on +4 and not -10 right?
Here are a bit of info from others who have OMNI interfaces.
http://duc.avid.com/showthread.php?t...dio+interfaces
Best Of Luck
Christopher
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 08-02-2016, 10:33 PM
Default Re: Omni HD
Pad button is not on.
Old 08-03-2016, 12:43 AM
Meads Meads is offline
Default Re: Omni HD
Happened to me as well. The Omnis up to a certain revision had an issue, that when you plugged/unplugged a mic while phantom power was on this somehow damaged the preamp.
Avid fixed it for free, even though my unit was out of warranty. It's a known issue.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 08-03-2016, 08:52 PM
Default Re: Omni HD
Yeah, I saw from the link, this is a common problem. Hopefully, Avid will stand by their product, even though the unit is less than 2 yrs old. I did notice in some posts that people were saying that these units were problematic before Rev D. Mine is a Rev A, which I can't figure, since it's fairly new. I guess this one had been sitting in the warehouse shelf for awhile.
Omni vs HD 8x8x8 io and Omni Pre's Southsidemusic Pro Tools HDX & HD Native Systems (Mac) 13 03-27-2013 01:00 AM
OMNI Fried? Calling Omni Members - Check High Samplerates KingFish Pro Tools TDM Systems (Mac) 3 11-03-2011 09:19 PM
Be aware! Potential HD Omni buyers with treated Rooms and Computers. Omni Noisy Fan FRaNCo MuSiC Pro Tools HDX & HD Native Systems (Win) 0 09-25-2011 05:42 AM
Can I use 2 HD Omni's at once? PostHuman Pro Tools TDM Systems (Mac) 7 02-06-2011 09:49 AM
New HD Omni Alιcio Costa Pro Tools TDM Systems (Mac) 280 08-19-2010 07:24 PM
