8 channels on interface clip with only one input activated
When I create a session with a mono track and stereo master fader, eight input meters on the HD io face light up red from time to time. Static always accompanies the phenomenon. The static will go away for a time and I can track; however, it returns at random intervals. At first, I thought it might be the eleven rack; however, I mic'd an amp last night and the issue happened again. I don't understand how input monitoring a single mono track would cause all input meters of the IO to light and clip from time to time. Also, every output meter on the IO is unlit while this is going on. This even happened with a session closed (Protools still running). When the static is absent, everything operates and sounds as it should.
I use a BA 500 series rack for inputs 1-4, eleven rack (set to mimic analog out and connected to the computer by USB for integration) for 5, LA-610 for 6, AEA-RPQ for 7-8. The C24 pre's are used for inputs 9-16. I record on a external seagate drive@ 32 bit, 96k. The clock is set to internal. Thanks for any suggestions. My current specs: Mac Pro 2009, 2.66ghz quad core, 16GB ram OS 10.10.5 Protools HD 11.3.2 HDX HD io 16x16 C24 eleven rack BA 500 series rack LA-610 AEA-rpq Last edited by fuzzbox87; 09-13-2016 at 01:39 PM. Reason: lack of information |
Re: 8 channels on interface clip with only one input activated
Hi and Welcome to the Community
Please review this and post back with the details needed to even start to investigate: http://duc.avid.com/showthread.php?t=300050 It is like me saying : hey my car doesn't work ! Whats wrong with it ? We need every peice of info you have as no one here can guess what you have.
Indeed^^^ Not enough info. If I were a betting man, I'd bet you have an external 8 channel preamp going in via a digital connection, and that you don't have it clocked correctly
pro tools midi input shows no channels activated | lexaudio | MIDI | 0 | 09-19-2013 10:51 AM |
no channels activated? | janhart | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-21-2010 09:27 AM |
No channels activated MIDI error in PT8 | compumar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-14-2009 08:23 AM |
"No Channels Activated"!!?? what!?? | The Crunt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 02-09-2005 04:49 PM |
no channels activated | jimll | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-22-2003 06:31 AM |
