Old 03-29-2013, 05:57 AM
Fritz Fritz is offline
Default playlist solo intermittent in PT9?
does any one know if this “feature” is fully threshed out in PT9.06?
I tired to use it for a mix to track yesterday and it’s rather intermittent.
The switch always works but the audio doesn’t necessarily follow.
ah well, wrong place, if only there was an actual delete button for posts.
"Do not fear mistakes. There are none."
Miles Davis
Old 04-06-2013, 05:09 AM
Drew Mazurek's Avatar
Default Re: playlist solo intermittent in PT9?
It's always worked for me. Granted there is a slight lag but I am usually pressing stop in between each switch and with this, there is no lag.
www.drewmazurek.com
A way to create a new playlist when re-recording over playlist section? jschmidtiii macOS 2 08-13-2013 02:28 AM
playlist solo intermittent in PT9? Fritz macOS 0 03-29-2013 06:00 AM
Protools 10: mute and solo aren't working. (Solo safe is not on any of the tracks.) charlottewrinch macOS 2 04-14-2012 05:32 PM
Solo-Yellow, Solo Clear-Green Imagine ICON & C|24 1 05-14-2011 04:55 AM
Grouped Track Playlist solo shortcut??? Epik Productions Pro Tools TDM Systems (Mac) 2 07-25-2010 09:51 AM
