MTRX Studio Rack Size
Has anyone else had a problem fitting the studio in their rack? I got mine last week and the plastic face plate seems to be just so slightly larger that the metal rack ears behind it and it wont fit into my rack.
I also have an issue with headphone 1 playing only out the left side unless I jiggle and twist the adapter, but with distortion in the right. It also causes distortion in analog out 2. I think there is a short somewhere. Hp 2 plays fine. All the rest of the outputs are ok as well. Prolly just a bad unit and I plan on getting it swapped out thru sweetwater, but if the awkward rack size is something across all the units the Studio might not be for me which is disappointing. I think the convertors are as good as my dangerous convert 2. |
Re: MTRX Studio Rack Size
Greetings,
I've racked several MTRX Studios in multiple racks and haven't had any issues properly occupying or fitting the rack boundaries. I can't determine from your photos exactly what the concern is? Jeff |
Your racks were made too narrow.
Sent from my SM-G986U using Tapatalk |
Yep. Doesn’t look like there’s any wiggle room at all on that rack. Mine have a couple of mm buffer on each side. I’ve got a few bits of gear that are slightly wider than others. Pretty common. Sent from my iPhone using Tapatalk |
@creativecontrol The plastic face of the unit extends slightly past the metal ears behind it and it wont go flush.
I have and have had a ton of rack equipment in my racks: Cl1b Avalon 737 Distressor La2a Heirtage audio 8 slot 500 rack 1176 Avid eleven 1073 vintage king rack Vipre Hr 500 Api lunchbox Precision 8 Switchcraft Patchbays And in this specific slot: rosetta 800 002 rack Symphony mk1 Avid hd I/o Everything else has fit. This is the first time ive had this issue in 15 years. Been out of town for the holidays but I will measure tmrw and report back |
FWIW, all my racks are built to 19.25" after having this issue with something many years ago.
@ albee1952 when I had mine built I never figured that would be an issue
I measured it today and as per my trusty tape measure the front panel came in at 19 1/16” Too bad. No mtrx studio for me... |
MTRX Studio with HD I/O | nedd | Pro Tools | MTRX & MTRX Studio | 37 | 07-04-2023 04:58 PM |
MTRX Studio i/o | Cheesehead | Post - Surround - Video | 9 | 02-21-2021 08:17 AM |
MTRX Studio clicks | Reckless Erik | Pro Tools | MTRX & MTRX Studio | 4 | 11-29-2020 05:30 PM |
MTRX Studio owners around? | atticmike | Pro Tools | MTRX & MTRX Studio | 0 | 11-14-2020 04:11 PM |
MTRX Studio - No AES?! | Ryan Young | Pro Tools | MTRX & MTRX Studio | 23 | 02-23-2020 02:13 PM |
