Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2020
Old 07-12-2020, 04:02 PM
mophilly mophilly is offline
Default iCloud and projects
MacOS 10.15.5, Pro Tools 2020.5.0
I have a couple of PT projects in the normal location: Documents/Pro Tools/Projects. Projects put there work as expected.
I set up a folder in the iCloud "drive." E.g. iCloud Documents/myProjects/MyNewProject. Imported an mp3 to use as a guide for other tracks. Saved the converted files to that location.
That seemed to work. I went away for a couple of days, and when I lit up the Mac and opened the project, I got the "missing files" warning for the imported mp3.
I looked around DUC, and poked around my system. The project was in the normal location, and the mp3 and converted files were in the iCloud drive.
I noticed the iCloud drive does not appear in the Relink window, and the command line path to iCloud is different that other MacOS volumes.
I am thinking the iCloud drive is *not* a good home for a project. I read posts from Darryl Ramm that give several good reasons for not using iCloud and other "slow" file syncs. Aside from those very good reasons, are there other potential snags?
iCloud to local peterbrookes Pro Tools 2019 2 01-04-2020 10:41 AM
Files under iCloud a bad idea? rcook349 macOS 6 11-27-2017 10:10 AM
PT First and iCloud Elbergo Pro Tools | First Discussion 4 05-03-2017 06:06 PM
iCloud has eaten my projects!? Daniel Barnes Pro Tools | First Discussion 1 02-08-2016 01:51 PM
iCloud... ANY Problems? Shifted Music Pro Tools 10 4 03-02-2014 09:52 PM
