Re: Pro Tools 7.4 freezing when Ilok inserted for Strike
There's a procedure that has to be followed. Did you register your Ilok? (free)
Once you've done that you can log into your Ilok account and view each and every authorization on that particular Ilok. Did you actually install the authorization on the Ilok when you purchased the program six months ago? Sounds like probably not. I (and I'm sure many others like me) have a couple DOZEN authorizations on mine. You plug it in and forget about it. (BTW, it's a good idea to use a 1-foot or shorter USB extension cable on it so it doesn't stick out the back and potentially get bumped and broken. Make your dongle dangle....) If you take the time to do this right it becomes a total non-issue. |
You said: Quote:
I would do what the others suggest - plugging the iLok in and leaving it in, or at least having it plugged in before you launch Pro Tools. Plugging it in at the time it asks for the iLok has not always been reliable. |
i used to have that same problem, and i bought stike! i just got tired of trying to run it and went back to bfd2.
I guess this would work if you use your computer for more than audio. I have mine attached to a hub (3 at one location, 1 at my second location). I leave them plugged in and let them start up/shutdown with the computer. however, I don't use those computers for anything other than audio. Check back with the guy talking about iloks on the other forum in about 2 years and see how his is working. I bet it will be worn out from being started and stopped so much.
Mac Pro 3.7 Quad Core Intel Mac OS X 10.13.2 PT Ultimate HDX 2019.10 64GB RAM HDX I/O 16x16 Analog HDX I/O 8x8x8 |
Strike freezing on PT10 | WarrenG | Virtual Instruments | 0 | 06-05-2013 12:42 AM |
Pro tools SLOW, and Freezing then continuing, then freezing again | DJX-RAY | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-09-2011 07:52 AM |
Installed Strike, activated license with iLok> no Strike. | seeeker | Virtual Instruments | 3 | 10-17-2010 04:21 PM |
Do I always need to keep my Ilok key inserted? | sebamars | Pro Tools TDM Systems (Mac) | 6 | 05-14-2005 10:24 AM |
Trouble registering inserted iLok | Renie | Pro Tools TDM Systems (Mac) | 3 | 09-13-2003 01:58 AM |
