Old 10-11-2018, 02:13 AM
RogerPaolo RogerPaolo is offline
Default can not remove Euphonix MIDI Device from MIDI studio
I want to remove the Euphonix Midi Device from my MIDI studio on my Macbook, as I don't use any AVID/ Euphonix devices with this computer.
It is however only possible to delete non-active MIDI devices, and the Euphonix device shows up as active. Anybody got a clue on how to remove it?
Old 10-12-2018, 12:35 AM
EddieJones's Avatar
Default Re: can not remove Euphonix MIDI Device from MIDI studio
Have you tried running the 18.3 installer then check remove all programs...and also check remove all prefs ?
Old 10-12-2018, 12:48 AM
I don't think I did use the installer to uninstall EUCON. Now I did, and now I could remove the midi device! Thanks man!
Old 04-16-2023, 03:00 PM
skystudios skystudios is offline
the installer is a bit out dated, but works if you look harder...
just wish you guys made it more simpler
original midi device associated with midi controller m keyboard could not be located willl3 Windows 1 09-23-2017 05:29 PM
Remove a Greyed-Out Device in Midi Setup? Reesho 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-14-2016 12:58 PM
003 midi ports not there in midi studio setup? Unable to record midi now? TREBLEBLEED 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-22-2009 12:06 AM
Midi problem - no INPUT DEVICE option in MIDI menu tam103 MIDI 2 01-05-2007 08:01 AM
Control PT recording features via MIDI from an extenal MIDI device Montxo MIDI 3 05-05-2001 08:05 AM
