MIDI Controller Problem
Hi! I'm using ProTools LE 6.4 and have installed Reason 3.0. I've inserted Reason as a plugin into a session and I'm attempting to control it with an Evolution MK-425C USB controller keyboard via USB. An error message continues to popup that says "The MIDI port may be in use by another application". It works fine when I use Reason in standalone, but when I use it in Protools via Rewire, I get the error. I looked in Answerbase for a fix, but I had no luck. Could someone help me with this?
Re: MIDI Controller Problem
What platform? Mac or PC?
If on a PC, you will need to use Pro Tools to control/record MIDI in Reason. If you must sequence in Reason, there is a workaround of unplugging the Evolution, then starting Pro Tools, then plugging the Evolution back in.
MIDI controller problem | ThunderHorse | MIDI | 0 | 08-06-2010 05:25 PM |
Midi Controller Problem | Shawnblack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-19-2008 03:07 AM |
Problem with Midi Controller | scottrolfs | MIDI | 0 | 03-08-2008 05:09 PM |
Problem with Midi Controller | mastermind423 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-04-2006 04:10 PM |
Midi Controller Problem | Wu-Zei | MIDI | 6 | 01-18-2006 10:42 PM |
