Old 07-13-2020, 02:11 PM
Ronnieb Ronnieb is offline
Default Re: Protools 003 rack
Correction, when I say upgrade, I mean to buy the new install of PT 2018. Right now I have PT 8.0.3 and can't be upgraded.
Old 07-13-2020, 02:12 PM
Originally Posted by Ronnieb View Post
The reason why I want to upgrade is because I can't use the quantize tool for stereo drum files anymore.
When did that start? Because you upgraded the OS to a version not supported by Pro Tools 8? If so it may be easier to fix that (roll back the OS version) than go through all this other pain and expense.
Old 07-13-2020, 02:13 PM
JFreak's Avatar
JFreak JFreak is offline
Relax Darryl, he may want to start with new PT license and buy new computer later
Janne
Old 07-13-2020, 02:36 PM
Yes. And understanding the motivation/issues here helps. There may be a lot of pain to go through in any upgrade if *all* the issues today could be solved with an OS X downgrade (assuming it's that which caused the problem).
Old 07-13-2020, 02:38 PM
JFreak's Avatar
Sure. But if the idea is not to stay with PT8 forever, it makes sense to first update PT using current hardware (which works! albeit experience probably will not be great) and then plan the hardware upgrade when the time and budget is right.
Janne
  #16
Old 07-13-2020, 02:50 PM
This is for Janne (others, ignore).
Thank you Janne. Where can I purchase / download PT 2018 (which is the compatible with my 003 rack, Mac Mini Late 2009, Mac OS 10.11.6).
  #17
Old 07-13-2020, 02:51 PM
JFreak's Avatar
Avid.com or your favourite reseller. Once you have the license you also get download links to your Avid Account
Janne
  #18
Old 07-13-2020, 04:27 PM
Ben Jenssen's Avatar
I just want to say that Darryl has a good point.
Personally, I'd rather run a stable PT8/compatibleOS on such an old mac, than experiment w/PT2018/Capitan. Especially if the only reason is the quantize problem which is most probably caused by the incompatible PT/OS versions.
003+ rack and Protools 12 Cabra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-25-2018 01:59 PM
Does the 11 Rack come with Protools? Studio.RED Eleven Rack 11 05-17-2015 02:58 PM
need help setting up protools 8 le with motif rack and trition rack(so newby to this) BeatBoy19 MIDI 0 06-01-2011 10:38 PM
ProTools 9 & 002 Rack mountainairmuse macOS 4 01-06-2011 02:48 PM
002 Rack with ProTools (not LE) roderickelms 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-21-2004 05:09 AM
