Mbox 2 Pro with Mavericks 10.9.2
Hello all
Upgraded my PT to 11 and MacBookPro to Mavericks, not realizing that Mavericks was now at 10.9.2 - officially unsupported by Pro Tools 11.1.2. PT and my Mbox Pro 2 function perfectly well, I've not suffered the audio problems (unless you count my terrible musicianship) that other have, however the Mbox or it's drivers cause the MBP to have a 'kernel panic' when waking it from sleep when the Mbox is plugged in. Doesn't happen if the Mbox is unplugged, or it's drivers are uninstalled. Anyone else suffer this problem? Anyone know how to make Avid aware of this? Cheers Ian |
Re: Mbox 2 Pro with Mavericks 10.9.2
Unfortunately Sleep or Hibernate are not supported by Avid: http://avid.force.com/pkb/articles/e...=0&subfilters=
Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
+11111111 NEVER use SleepMode or powersaving modes when using Pro Tools. It will never function as it should and you will have nothing but problems so turn Off the sleep and power saving stuff and start working with a better more stable system
Best Of Luck Christopher #hitmakers
Never had a problem with PT 9 or 10 doing this under os x 10.6.8..... Oh well that explains it!
Thanks for your replies everyone. Ian |
I have the same issue on 10.9, but with a mac mini:
http://duc.avid.com/showthread.php?t=349638 It definately appears to be the mbox driver that causes the mayhem. I had somehow hoped that it wasn't and that it was something that could be fixed via the next OS update, but now I see that won't solve it. People in other threads have experienced similar with different mac setups, but they thought it had something to do with TB/FW adapter.
i7 5820K, 32GB | Windows 10 Pro, PT 2021.10 Ultimate | RME FF802 |
Ooooooh! I have similar issue
Ive been using Pro-tools 11.0.2 on Mac 10.8.5 with Mbox 2 interface but recently updated to pro-tool 11.1.2. After constant nagging from Apple to update my Mac, I gave in thinking the update was to OS X 10.9.1, which I understand is compatible with pro-tools version mentioned earlier. I later realized I have updated it to OS X 10.9.2 now I can get no sound at all from my M box 2. Im hoping anyone could help, please? I have tried being to Set up, I / O settings, clicked on the input button and clicked on the default button. I have done similar at the output button and clicked the default, and then clicked on the okay button for reset but all to no avail Is there a way of uninstalling the OS X 10.9.2 and re-installing OS X 10.8.5 Im hoping avid will come out with some solution to this because it looks like the issue is to do with the M box 2 drivers needing updates. ALui |
This does not sound like the same problem the OP was talking about. The OP was having a problem with waking from sleep/hibernate.
Is your mac a core 2 duo? If so, please see this KB article:http://avid.force.com/pkb/articles/e...OS-X-Mavericks a possible workaround is using a cheap USB hub. Joel
Hello all.
https://discussions.apple.com/thread...rt=60&tstart=0 strangely, this has possibly solved this really irritating 'feature' where my mbox pro 2 crashes if the Mac sleeps. Don't know if it's solved the dual monitor issue yet though! I used kext wizard to replace my amd drivers with older ones, now I can use the mbox pro 2 after the Mac sleeps - providing I unplug the mbox before waking the Mac, give it a few seconds to pull itself together then plug the mbox on again. Hope it works for some one else too! Ian |
Mbox 2 on Mac OS X 10.9 (Mavericks) | Jonnyb27 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 46 | 09-15-2014 05:27 AM |
Mbox 2 and Mavericks 10.9.1? | formento | FireWire & USB Audio Interfaces (Mac) | 4 | 04-10-2014 09:37 PM |
Mbox and OSX Mavericks | seeeker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 03-24-2014 03:57 PM |
Mbox 2 and Mavericks 10.9.1? | formento | FireWire & USB Audio Interfaces (Win) | 1 | 02-04-2014 07:26 AM |
Mbox 2 & Mac OS X Mavericks 10.9 | Jay_Red27q | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 12-28-2013 08:44 AM |
