Old 03-22-2019, 07:00 AM
twistedinsane twistedinsane is offline
Default Help me out!
Ok so, I now have PT 11 using on my macbook pro mid 2012 with mohave 10.14.3 on it. Everything works perfectly in PT except importing audio, Im forced t drag and drop (takes forever). I want to upgrade my computer to a mac mini 2018 6 core i7 2 TB 64gb , and I want to upgrade to PT 2018. My question is , will it work? Does anyone have that configuration? Does import audio work? Should I have High Sierra installed on it first as I heard if you have Mojave you cannot install PT so I would have to put high sierra on it, install PT and then update. Any advice ?
Old 03-22-2019, 02:20 PM
danyg danyg is offline
Default Re: Help me out!
why should it not work? What happens when you import audio ? Any messages ?
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32
Old 03-22-2019, 07:00 PM
amagras amagras is offline
What audio format are you trying to import?
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 03-22-2019, 07:43 PM
Sardi Sardi is offline
The OP is running v11 on Mojave.
The import problem has been a known issue on unsupported Mac OS’ for sometime.
Old 03-23-2019, 12:15 AM
cwsand's Avatar
cwsand cwsand is offline
Yes, make sure you have a compatible system:
Pro Tools Operating System Compatibility Chart
Compatibility & Upgrade Information for Pro Tools on Mac
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 03-23-2019, 03:49 AM
Goes back to PT11 on Sierra. Been running that combo for about 9 months now and it's been just fine other than the import audio bit. Drag and drop works just fine and isn't all that slow.
Jack
QAPLA!
