Old 09-25-2006, 01:52 PM
Johncmuzic Johncmuzic is offline
Default Record to disk vs bounce to disk
I am trying to rtd instead of bouncing to see if I notice the sound difference. I was wondering how do you apply dither with RTD since you are recording back into the same session that you are mixing in that is a higer resolution than 44.1 16 bit? I have all my tracks bussed to a stereo Aux that has all my master fader plug ins and it is feeding a stereo track for recording. So I am wondering where to put the dither plugin?
Old 09-25-2006, 02:11 PM
ProTooler ProTooler is offline
Default Re: Record to disk vs bounce to disk
just record back into the session on a new stereo audio track (don't forget to mute the outputs). don't dither at this point. import new file into a new session w/ the same bit depth and sample rate and use dither plug on a stereo master fader. now bounce to disk.
hth...
Have a great day.....
Bill
Mac Mini (2019)
3.2 Ghz - 6 Core i7
Mojave with 64 GB RAM
PT Ultimate (2019.10)
Motu 16a
C/24 Control Surface
Old 09-25-2006, 02:18 PM
Drew Mazurek's Avatar
record back into the session, then Command/Shift-K to export selected as files and Dither is applied automatically.
www.drewmazurek.com
Old 09-25-2006, 05:38 PM
how is dither applied automatically?
Old 09-25-2006, 05:52 PM
Will Russell's Avatar
Will Russell Will Russell is offline
From page 151 of the Reference Guide:
"When you export regions to a lower bit depth,
Dither (with or without Noise Shaping) is ap-
plied as shown in Table 10.
The Dither setting used for any conversion is the
Digidesign Dither plug-in ..."
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 09-25-2006, 06:19 PM
mftorso mftorso is offline
Due to Ross Hogarth and others at the forum "whatever works" talking about it, I, like others, tested extensively comparing bounced files to recorded files of the same exact material/mix.
I, like others, was stunned at how much better the "re-recorded" files sounded compared to the bounced.
Now I record back to my session religously instead of bouncing. When dither is needed, for example mastering something down to 16 bit, I apply the dither at the end of my insert chain, record back to the session ( the dif. between 16 and 24 being empty bits) and once done, export as the file type needed as 16 bit files.
A truly superior method that I was not aware of until following an excellent thread at WW forum.
Best,
M
Old 09-25-2006, 08:50 PM
Dimension Zero Dimension Zero is offline
Really?
I thought this "Record to Disk" thing was an urban legend.
What versions of Pro Tools does this apply to? It can't be all of them. v5, v6, v7? Digi I would think would resolve whatever problem "Bounce To Disk" has if this is truly the case.
Monty
www.dimensionzero.com
Old 09-26-2006, 01:27 AM
Andre Knecht Andre Knecht is offline
[…] Digi I would think would resolve whatever problem "Bounce To Disk" has if this is truly the case.
Considering how hard it seems to be for DUC members to check whether “their” topic is already being discussed in an existing and current thread, might just be the perfect illustration that… very little is obvious—apparently.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 09-26-2006, 08:29 AM
Seeee Seeee is offline
Yeah, I record to disk too but I always apply the dither (when doing 16 bit reference mixes) on an aux on the way back in when I am limiting. Of course i have an undithered 24bit mix and dithered/limited/smashed/client cut 16 bit mix both recording at the same time. try THAT with BTD.
Old 10-31-2006, 04:33 AM
CharlesL CharlesL is offline
if I do not want Digi's dithering to be applied during RTD / BTD, do i turn it off in Setup/preferences' Processing/AudioSuite/Use AudioSuite Dither ? it is ON by default, right?
.. TWO ROOMS pte ltd
.. Audio Post Production
.. www.tworooms.com
Bounce To Disk or Record To Track??? Audio quality... RWTV Tips & Tricks 12 10-23-2013 01:52 PM
Bounce to Disk intermittently causes freeze and disk unmount after PT 10.2 Upgrade AllThingsMusicStudio macOS 0 06-28-2012 07:16 PM
could not complete the bounce to disk command because: a disk is full -34 help? Henrydm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 03-27-2010 09:07 AM
LE's Bounce to disk vs. Reaper Render to disk gbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-16-2009 04:49 PM
Bounce to Disk - Record on CD digimog Tips & Tricks 8 07-02-2004 08:03 PM
