#41
Re: Real-Time Bounce to Disk...REAL PAIN
Time is money and as a voiceover professional who also produces/edits audio for imaging, radio programs etc., the ability to bounce quicker than real time is so needed. Again, I have used a few other programs that have no issue whatsoever bouncing faster...Cubase being one of them.
I have had clients sitting a waiting for audio and I'm sweating as it bounces. When I add bounce time and then FTP upload time...it baffles some customers! I simply feel that this option should be available for those of us who need it. Heck, as many folks as I have referred that have actually purchased Pro-Tools at my recommendation (even with the bounce issue), Digi should at least consider the idea!! Guys, thanks for your comments!
The Voice of Brian Mac Studio M1 Max, Focusrite Clarett2Pre, Sennheiser 416, sometimes Beta Tester for iZotope |
#42
What is the official Digi attitude on this?
This is obviously a pretty big issue for alot of people. So, Digi Admin, where does the company stand on this issue? Someone out there must be listening...... |
#43
TDM requires it, but LE doesn't - unless you're using an external compressor/EQ or Synth. My guess is that Digi doesn't want to offer a feature to LE users that isn't available in TDM.
Most of the time, my music clients like to listen to the bounce. I can put them in my chair where they're in the sweet spot while it rolls along. However, it's a real PITA for scoring and dialog/voiceover editing - anything longer than about 5 minutes. There, the clients DON'T want to wait. They just want the CD. Burning direct to CD would also be a great option. You can do that in Logic Pro.
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
#44
#45
Greetings and Hello,
Years ago I used Cream-Ware /Master port/osiris on PC, archaic but poignant! But nothing compares to the grace and stability of ProTools of today. However I can not express enough my disappointment towards limiting the user to the time-consuming arduous task of the "Bounce to disk" exportation in real time. I own Diamond waves Bias and Cube high end plugins, Yet ProTools Le 7 will not let me render or quickly "export" effected project material through Rats, in the file format of my choosing. In RTAS I can play, mix and adjust the plugin to a fine sense of accuracy, involving hours of careful consideration and discernment using several effects, only to then have to switch, loosing every sense of realtime handling in the cumbersome "Audio Suite". The ProTools "Audio Suite" is stable like a Rolls Royce, But It is cumbersome and choppy to work with, and the "Process" function dissociates the user from the material. I purchase Bias Peak Pro 5 just so I could render and effect .aif files quickly. I also just purchased Cube de-hiss, It will only work with ProTools, But the Audio/Suite "process" interface looses touch with the effect handleing. An analogy to this would be playing classical guitar with mittens on. All I want to be able to accomplish is to "render" in RTAS , and export effected project mixes in wave and .aif formats through the mixer! Working with 45 minute material makes this function absolutely imperative. MP3 and OMF is limited for special use... But we desperately need an export( .wav .aif )plugin. to complement the "Mixer" and to be able to render files through RTAS on the fly... Bounce should be a secondary option! |
#46
Regardless of one's stance on this issue, there IS A PLACE for "faster than real-time" bounces. All points made by folks on this thread I started are good...thus, THE OPTION SHOULD BE AFFORDED to all.
-Listening during bounce (good idea) -Listening after bounce (a must) -Being able to give clients audio's video-equivalent of "daily's" without packing a lunch/dinner/snack while it bounces (a must) -For VO folks like me with only a few tracks (sometimes more if producing imaging etc.), faster bounce option (a must) Honestly, there should be no tension on this issue, it simply should be done by Digi, without question, as this "industry standard" software should have all the reasonable "tools" at the users disposal...end of story! Brian in Charlotte www.VoiceOverforyou.com Blog: VoicePro.blogspot.com PowerMac G5, LE, 002
#47
<revision and apologies>
ask your self this question. If ProTools offered a faster than realtime bounce as an Export Command. Or allowed the export rendering of RTAS through the Mixer, would you use it? |
#48
#49
#50
audio quality?
what could be the problem with the audio quality while bouncing faster-than-realtime? It's a computer! It's digital! there's no tape inside! Do you think that because of faster transfer your wav file will be lower quality when copied from hd to an usb stick than it'd be when copied to a floppy???
nonrealtime btd is a MUST.
"The Mackey Big Knob is, you press little button and they can hear through the headphones, you can say whatever you wanted to them without you having to yell." by Tad Donley |
Non-real time bounce | arturoquispe | General Discussion | 2 | 09-05-2010 11:24 AM |
Why Bounce to disk happens in real time? | ESR | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-01-2003 03:56 AM |
Getting Around the Real Time Bounce? | bloodspoint | Tips & Tricks | 6 | 01-02-2003 10:19 AM |
Is there any way to bounce/export a full mix to hard-disk without doing it Real-Time? | Shutz | Digidesign Hardware & Software | 5 | 09-17-2002 06:14 AM |
Dear Digi: 8 reasons to bring back non real time bounce to disk | apetrocelli | Pro Tools TDM Systems (Mac) | 15 | 12-04-2000 11:47 AM |
