Old 01-24-2023, 08:37 PM
luke88 luke88 is offline
Default Delay Comp issues since moving to 2022.12
Been on HDX/Ultimate for years.
Over the holiday I upgraded to a Mac Studio M1 MAX. Using newest version of PT (2022.12), under Rosetta. Updated all my plugs. Here's the thing- I immediately started noticing some weird phasey stuff happening when I parallel process. Same plugs I've always used to do that- except it was always rock solid on my old rig. I've tried all options of HW Buffer, etc. Nothing helps.
Using UAD-2 Octo, and a Quad Satellite. The HDX/OCTO are in a Sonnet Chassis and connecting via thunderbolt. I should note that I am NOT using the Hybrid Engine at all.
Is anyone else experience weird delay comp/latency issues with 2022.12?
Old 01-25-2023, 08:50 PM
Eric Lambert's Avatar
Default Re: Delay Comp issues since moving to 2022.12
Did you also recently update your UAD plugins? I've heard of timing issues with a recent batch of plugz. Or are you having issues with other non-UAD plugz too?
I'm using 2022.12 via Rosetta with a Mac Studio Ultra and haven't noticed any delay comp issues. BUT, it's ProTools, and they've had sporadic and unpredictable issues with delay comp since its inception.
Old 01-26-2023, 05:11 AM
YES. I had to upgrade the UAD-2 software. I am definitely noticing it on the Chandler Zener. Haven't tried others yet. I believe its v10.1.
I am pretty sure I'm hearing a bit with Plugin Alliance stuff as well. Will do more testing today.
Old 01-26-2023, 11:43 AM
DCProductions DCProductions is offline
AHH!!
I am have the most INSANE delay issues with the newest Pro Tools.
HDX- Aurora n.
it is samples off with all hardware inserts, and even my 2 lynx won't be synced.
the only solution (sometimes) seems to be shutting EVERYTHING down, including a power cycle of the chassis. beyond frustrating.
I've had this setup for years and it's never been an issue.
hardware inserts are off by 34 samples.
issues: HDX-2 (PT10) delay comp…. RTAS & hardware inserts MixerGuy Pro Tools 10 8 10-06-2014 03:21 PM
Delay Comp issues brdst Post - Surround - Video 1 02-01-2013 09:21 AM
Strange Delay Comp Issues / Phasing eledu Pro Tools TDM Systems (Mac) 0 07-17-2012 08:36 AM
Reamping with PTHD - delay comp issues DUCHUNTER Pro Tools TDM Systems (Mac) 14 10-02-2011 04:05 PM
8.0.3 serious delay comp issues! magnoman Pro Tools TDM Systems (Mac) 7 01-09-2010 12:16 PM
