Old 08-31-2016, 08:17 AM
vin7 vin7 is offline
Default midi notes going in and out of tune?
for the past few days my midi is in and outof tune, it happens at random? sometimes its nearly as if im moving the mod wheel on the midi keyboard.
Old 08-31-2016, 08:24 AM
Stig Eliassen's Avatar
Default Re: midi notes going in and out of tune?
Can you see anything in the MIDI event list after recording? A friend of mine had a similar issue, and discovered that the pitch bend was the culprit.
Old 08-31-2016, 08:32 AM
where do i check for this? sorry
Old 08-31-2016, 08:36 AM
No worries.
Go to Window (menu) > MIDI Event List
Old 08-31-2016, 09:37 AM
I checked the midi event list and i do see pitch bend in there a few times. How do i fix the issue? This happens when im just playing with the track armed or just monitoring.
Old 08-31-2016, 09:56 AM
Well, he told me that the pitch bend on his Roland XP-80 started to act up, so he filtered it out from the MIDI recording.
If you go to Setup (menu) > MIDI > MIDI input filter, and turn pitch bend off - does that help?
Old 08-31-2016, 12:38 PM
amagras amagras is offline
That happens with the pitch bend on my M-audio keystation61, I have to check the pitch bend automation lane every time I use it. Apparently it's a mechanical problem
amagrasmusic.com
Old 08-31-2016, 10:51 PM
jeam25's Avatar
jeam25 jeam25 is online now
Yes...I had a keystation pro that cause the same behavior.
When i started to hear some things out of tune it was the pitch bend on some midi track randomly automated . So i had to reset it one by one on the pitch bend track view . Very annoying indeed !
Avid Carbon Interface
Protools Ultimate
Old 09-01-2016, 04:47 AM
The root cause is mechanical due to the spring or whatever is used to return the pitch bend wheel wears out and won't always properly return the wheel to dead center.
Old 09-01-2016, 06:02 AM
In mine is not exactly that, I had it fixed once before and the engineer said it was electrical. Anyways, no more m-audio for me.
amagrasmusic.com
Midi is played on time but midi notes are early on play back. steveooo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 09-30-2022 12:17 PM
how to set all midi notes to 1/16 notes? musicmixer04 Pro Tools 12 7 04-25-2016 05:11 AM
Waves Tune help- distorting some notes! DeweyDewey macOS 0 04-10-2012 07:16 PM
Recording Midi notes and keeping existing notes during record Sherbert99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-15-2008 09:40 AM
Why are midi notes so small in notes view Gothboy MIDI 1 05-27-2008 06:17 AM
