3rd party plugins not showing up in session
Hi there, I'm having trouble getting my Guitar Rig software to show up as a plug-in in PT. It worked before, but a few months ago I had to re-install PT and it hasn't shown up since. The native plug-ins are visible and operational, though.
Spec-wise, I'm using a Macbook Pro w/ a 2.8 GHz processor, running OS X 10.9.2. My interface is an M-Audio Fast Track Pro, and I'm using Pro Tools 11. I'm also using an external hard drive, an OWC Mercury Elite AL Pro, connected with a FW 800 cable. I've already checked Mac HD>Library>Application Support>Digidesign>Plug-ins, and Guitar Rig 5 is in there. I also checked the version, saw it needed to be updated, and did so, to version 5.2. However, it still isn't showing up in PT, and I'm not sure what the next step is. Any help would be much appreciated! |
Re: 3rd party plugins not showing up in session
HD>Library>Application Support>Avid>xxx for the .aax plug-ins
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
I'm actually having this same issue, and I just posted my question here:
http://duc.avid.com/showthread.php?p...=1#post2182627 I found the plugins folder at Library/Application Support/Avid/Audio/Plug-Ins, and everything seems to be in order. All of the Avid plugins are there, as well as all the 3rd party ones that aren't showing up in PT11. Any other possibilities? |
Are you sure you've installed latest versions, eg Native Instruments implemented 32bit AAX before 64bit? The 32bit versions still get put in the Avid Plugins folder.
Do they appear in Pro Tools 10 (if you have that co-installed)? If they do, then remove any .dpm versions in the digidesign folder to the unused plugins folder, and relaunch PT10. If those plugins still appear then you have 32bit AAX versions installed. All current NI stuff is now 64bit and appears in my PT11. The latest installers all install aax versions that include both 64bit and 32bit elements.
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10 iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6 Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors. Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3. Various apps, soft synths, FX plugins. Plenty of hardware synths, rack gear, microphones etc. And then there's the studio ;-) |
Third Party Plugins not showing up in PT11 Trial | criss626 | Pro Tools 11 | 7 | 05-02-2016 08:07 AM |
Third party plugins not showing up in PT11 | edwinh | macOS | 5 | 09-02-2013 02:25 PM |
Deleted PT Prefs now 3rd Party RTAS aren't showing up | imdrecordings | Windows | 0 | 10-04-2011 07:42 PM |
3rd party plugins w/PT8... | lwilliam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-14-2009 05:42 PM |
Plugins not showing up in Protools session | Wil | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-05-2004 03:29 AM |
