Old 06-18-2010, 01:08 PM
RogerAF RogerAF is offline
Default Changing the device Playback Engine uses
I just finished installing Pro Tools LE 8.0 and MBox2 on a Win XP computer. After much head scratching I got a an input to work and recorded a track through the MBox2. The computer has built-in sound on the motherboard and I want to playback through that, but it isn't listed in the Playback Engine or any of the Setup menu choices. My Windows control panel has it as the default device, but Pro Tools is ignoring it. In the Setup menu, Hardware lists only MBox2.
I went to the index of the Pro Tools Reference Guide (in the Help menu) and looked up "Playback Engine". There is one page listed: 1010, but there is nothing on the page that refers to the Playback Engine. Doing a "Find" search in the pdf document, I found several instances of Playback Engine. But none had anything about how to select a different device.
Can anyone tell me how to do this?
Old 06-18-2010, 01:53 PM
spkguitar's Avatar
Default Re: Changing the device Playback Engine uses
<snip>
No can do. All audio output from Pro Tools has to come out of the Digidesign/Avid/Pro Tools hardware (the MBox 2).
If you want/need audio to come out of the computer's built in soundcard, you will need to use different software.
Old 06-19-2010, 09:19 AM
bariguitar bariguitar is offline
I use PT LE 8 in a Windows XP system myself--with MBox2Pro. On the back
of your MBox you will find 1/4" monitor out jacks. Just plug a pair of powered
monitor speakers (I use M-Audios) into these and you're good to go as far as
hearing the audio of your recordings.
Best wishes
Playback Engine Setup, Pro Tools Agg. or the actual device? Blackwell99 macOS 2 05-27-2012 04:24 PM
10.1.2/10.1.3 crashes when changing Playback Engine settings RokVox macOS 128 05-22-2012 01:51 PM
Changing playback engine size=Buss Error & crash bruce lang Pro Tools TDM Systems (Mac) 23 11-23-2009 09:13 AM
PT crashes when changing Playback Engine Will Russell Pro Tools TDM Systems (Mac) 11 12-05-2006 08:15 AM
Changing Playback Engine in 7.0 Ozzie Pro Tools TDM Systems (Mac) 3 11-11-2005 11:11 AM
