Old 01-26-2009, 04:26 PM
barstool719 barstool719 is offline
Default Re: low latency recording vs low hardware buffer size recording
Originally Posted by therecordinghouse View Post
you should probably read up on LLM. this information is incorrect.
i would say that it does work. ^^
guitar on input 1 on the aux, eleven on the aux, bussed to 7, audio track input to buss 7. audio recorded most definitely sounds like the plugin is active. no sample delay on any track.
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64
Focusrite Saffire Pro 40 / Pro Tools 9.0.3
Mics, Guitars, Amps, Basses, Drums, Keys
http://overtheeffect.bandcamp.com
Old 01-26-2009, 05:00 PM
chrisdee's Avatar
chrisdee chrisdee is offline
Reguarding the delay I experienced it was mostly caused by the master fader track (with no plugin on). When I disabled the master fader track the delay dissapared.
Old 01-27-2009, 02:41 AM
chrisdee's Avatar
Any input on my UA LA-610. Am I using it wrong or maby connecting it the wrong way ?
Old 01-27-2009, 06:49 AM
manyrains manyrains is offline
I'm not very good at talking about this, others here are much better, but until someone smarter comes along- I would think you want to make sure you're bypassing the Mbox pre- perhaps making sure going line in as opposed to mic? I got an expensive pre a while back into my 002r and it definitely makes a difference. Is there some way to switch between mic and line?
H/W Buffer size stopping recording ? JamesUdesky macOS 0 02-17-2012 03:12 PM
Buffer Size Recording Error link197 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-13-2009 08:39 PM
Buffer size problems(too little then too much) during recording nathanh26 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-02-2009 09:19 AM
Recording at 256 hw buffer size now causes error deanguidry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-14-2006 02:17 PM
Recording Latency, Buffer Size, Plug Ins JDL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-11-2003 08:26 PM
