Old 04-10-2021, 05:31 AM
Cayce Cayce is offline
Default Retain Settings on Session Data Import
I'll often have a group of tracks I've refined to a point that I'd like to import that group to be used in another session. Let's say, an acoustic guitar record setup using multiple mics and a DI with dedicated sub & FX tracks. All tracks have been adjusted and balanced to work perfectly with each other. When I do a session data import into another session, though, critical settings are in disarray, such as volume, etc. All automation selections are set to "Read" on import, which is also annoying.
Is there a means by which session data can be imported and maintain all original settings of the tracks?
Thanks.
Pro Tools Studio, 2023.3.0
Mac OS: Ventura 13.4
System: Mac Studio 2023, Apple M2 Ultra, 128GB Unified Memory
2TB Internal SSD
Apple Studio Monitor, 27"
3 External Monitors: 27", 27" & 65"
Apollo X8P Mixer Interface
PreSonus 32R Mixer Interface
Old 04-10-2021, 08:09 AM
Default Re: Retain Settings on Session Data Import
Never seen an issue with importing session data if everything is set correctly - do this many times a day. Would need to see the session data import parameters. Also, be sure the tracks you're pulling in are clean; no auto breakpoints anywhere, etc...
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Import Session Data or OMF Import creating regions of white noise Rob S Pro Tools 2019 0 09-23-2019 01:43 PM
Import Session Data Default Setting dalonso66 Pro Tools 2018 3 12-20-2018 05:38 AM
Import session data setting/bug? Guy McDude Pro Tools 10 0 07-21-2014 01:52 AM
import session data without audio data rgalpin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-06-2010 01:49 PM
Import track color in import session data deardaddy Pro Tools TDM Systems (Mac) 5 06-11-2007 06:35 PM
