Old 02-20-2008, 04:01 AM
eddiewes eddiewes is offline
Default CPU overloading PT7.4 CS2 and MP
Hello
My CPU starts to overload after that I have been away for a couple of minutes. When looking in Windows Task Manager it seems that Protools is using all the CPU-power. After starting my project the CPU goes back to normal again.
Anyone who knows how to fix this?
My PT config
H/W Buffer size: 1024
RTAS Processors: 2
CPU usage limit: 85%
DAE Playb Buffer: 1500ms (Default)
Cache size: Normal
Old 02-20-2008, 08:00 AM
DigiTechSupt's Avatar
Default Re: CPU overloading PT7.4 CS2 and MP
You should start with the steps in the Win XP/ Pro Tools 6.x/7.x General Troubleshooting thread and post specific info on your system per the info on that thread if you're unable to resolve the problem.
Avid Audio Tech Support
Support FAQ
Old 03-09-2008, 03:46 AM
Problems solved.
I figured out that something was wrong with a recorded audio file so I used Wavelab to open all audio files and then saved them again in the same format and folder and then I restarted protools, opened my song and then it all worked again as it should.
Just another day with Protools problems solved after a couple of hours with non productive work.
CPU overloading Che_Guitarra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-17-2007 07:54 PM
Overloading DIGI 002 GTBannah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-14-2007 10:08 AM
Overloading CPU That Once Was Fine... Brian Storm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-08-2007 11:45 PM
preamps overloading BruceBaklarian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-13-2004 09:23 PM
PCI OVERLOADING OHENEBA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-17-2003 07:08 AM
