  #71
Old 06-19-2018, 04:49 PM
SigFriedChicken's Avatar
SigFriedChicken SigFriedChicken is offline
Default Re: Pro Tools Ultimate CPU Spikes.. come on!!!!
I've found that doing stuff on the second display will invariably cause a spike.
  #72
Old 06-19-2018, 05:20 PM
YYR123's Avatar
YYR123 YYR123 is offline
Originally Posted by toolz View Post
.....I'm eagerly waiting on this critical bug fix, and maybe a 9 month refund on my support fee, as I had to spend two weeks uncovering this issue, that seemed to pass both Avid CS and Beta team....
https://youtu.be/z82ZrOE0Dq4
You pay to be a part of that team....that’s what that payment is.... for.
Seriously though, good catch!!!!
Daniel
  #73
Old 06-23-2018, 04:14 PM
685 685 is offline
I need to keep an eye out for this one. Thanks!
I'm curious to know what Boot ROM Version is listed on you guys' system reports for your MacPro.
  #74
Old 06-23-2018, 07:59 PM
SomeOtherGuy SomeOtherGuy is offline
Interesting, I run my video on a second display, I'll have to switch that off and see what happens. Thanks.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs
  #75
Old 06-24-2018, 08:56 AM
Still getting CPU overloads and transport stops with a single video monitor. About 20% of the time I'll get an overload during a Bounce.
Again, this all started with High Sierra and 2018.1 PT.
  #76
Old 06-25-2018, 11:57 AM
s.d. finley s.d. finley is offline
I have 2 video screens running on a single video card, no problems with that. I normally only get the buffer errors when I am recording or if the transport is engaged and I initiate a plug in, then I will get an error. I am using Sierra and 2018.3
sdf
www.sugarhillstudios713.com
  #77
Old 06-25-2018, 12:37 PM
skizzo skizzo is offline
So I do not run Ultimate/HD versions currently but I discovered a new spike issue recently.
When I powered on my Ddrum DDTi, which is literally just a trigger interface for converting triggers/pads into MIDI data, I kept thinking this totally froze PT 2018.4
I kept getting the dreaded beach ball that would never go away. But finally after I accidently walked away for several minutes with it up....the beach ball stopped and the program began to respond again. It just took forever for it to be recognized.....but then more troubleshooting proved I needed to have the MIDI track armed for that beach ball hang up to happen.
The CPU % jumps to literally 100% from 39% with this issue. And it stays spiked like that even when PT begins to respond again.
I also noticed I could eliminate this totally if I run with 512 or more sample buffer rate. But that obviously is not ideal for tracking which is what I need the DDTi for. I normally run at 64 sample buffer rate, again, for obvious reasons.
One other thing that is a workaround is if I disable SD3 and then enable it the CPU spike goes away and doesn't come back....unless I power on/off the DDTi and/or disarm/rearm the MIDI track.
I did not have this issue going all the way back to PT 8LE so this is something related to my setup's compatibility to the newest version of PT
Mac Pro '09 - 5,1 - Dual Hex Core X5680 3.33 ghz CPU - 48GB RAM
970EVO 500GB (10.13.6) - 1TB WD Black HDD (Samples) - 6TB Toshiba HDD (Backups) - 500GB Glyph GT050Q (Legacy sessions & backups) - 3TB Glyph Studio (Main audio/sessions)
HD5770 GPU
OSX 10.13.6 - Pro Tools 2018.12 - Presonus Studio 192 / Digi 003 Rack+
Focusrite Clarett OctoPre - AKG HPE6 - DBX160A - WA76
  #78
Old 06-26-2018, 04:52 PM
toolz toolz is offline
I'll be cheeky and say.. Avid need to sit with a computer running Logic, and witness their failings in the VI department, Logic goes forever!
Waiting for the next update, since 12.8.2 release on the 22nd of November 2017, that the code broke for me, on my supported Mac 5,1 and all Avid Hardware...
Avid replicated the bug! over two months ago!
Maybe I'm gonna invoice Avid! having wasted two weeks of my life pointing out problems with their release that a flagged critical bug, whilst continuing to pay for support and updates, that don't work for me. Totally hitting the wall with this!
All I can fathom is.. the very architecture on TDM (and having to integrate that factor), or however you dress it up as, has to be the biggest bottle neck of the software going forward.
I'm planning an open letter to Avid, if my computer won't run the next release.
[B][SIZE="1"]System:
PT 12.8.1 HD-Native PCIe, 48 I/O 16x16, 2012 Mac Pro 12 core 3.46Ghz 64gig RAM, UAD Quad FW, Apple 30” Cinema
  #79
Old 06-27-2018, 02:31 PM
YYR123's Avatar
After invoicing don’t forget to charge late fees for non payment and accrued daily interest rates!!!
Daniel
  #80
Old 06-27-2018, 04:14 PM
I came to PT from Logic. Maybe it was just me, but I found that Logic was no better when it came to CPU spikes and general stability.
Pro Tools Ultimate YYR123 General Discussion 13 04-08-2018 10:24 PM
CPU Spikes in Pro Tools 10, 11, and 12. julia12345 macOS 9 11-25-2015 07:07 AM
How to add Komplete 8 Ultimate into Pro Tools 10 LE Ryan Tunis Pro Tools 10 3 02-02-2012 02:13 PM
Vista Ultimate 64 (the ultimate dissapointment) Filmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-03-2009 04:44 AM
