Old 09-04-2014, 05:12 PM
Prabha Prabha is offline
Default Pro Tools could not set sample rate to specified value
Hi Guys,
I'm getting this message after working on a 48Khz session (99% of the time I use 44.1Khz).
My hardare is a SSL MX4 that is slaved to external clock.
But even when the external clock matches the session clock, PT refuses to open it. (actually any session).
Setting the card's sample rate to internal does not help.
This is PT11.2.1 in wondows 7. But I suspect it is not a problem of PT11 only.
Any suggestions?
PC i56600K 3.5Ghz 16Gb ram
Win 7 64
SSL MX4
Old 09-07-2014, 02:46 PM
Default Re: Pro Tools could not set sample rate to specified value
Today I had an unpleasant surprise.... It seems that PT has problems switching sample rates, no matter what interface are you using !
On a completely different PC with a Scarlett 2i2, opening a 48khz session on a system that usually works on 44.1khz, I get the following message after pressing play:
Pro Tools could not initialize the Focusrite USB 2.0 Audio Driver. Please make sure the device has been configured correctly.
Then trying to open a 44.1 session I get the same message.
Why switching sample rates on pt using asio on different computers with different interfaces, renders the software unusable ?!?
Win 7 64
SSL MX4
Old 09-07-2014, 04:27 PM
Top Jimmy's Avatar
If you are using the hardware for windows audio, then that's your problem. Don't use your audio interface for windows audio if you want to use Pro Tools.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.4.
Pro Tools HD Native 2020.3, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 09-07-2014, 06:33 PM
unkJE's Avatar
unkJE unkJE is offline
Make an easy Windows Desktop Shortcut for Pro Tools Audio:
Old 09-07-2014, 06:36 PM
Thanks James,
I followed your advice, and set other audio hardware as the default device for windows.
Set the desired sample rate (48.000) under the windows control panel for the audio hardware.
Also set the desired sample rate from pt hardware setup and set the sample rate.
Still pt says can't initialize the sound card. (Scarlett). When attempting playback
Funny thing is, it works OK for 44100 ! At least in this home studio setup.
Don't know what's going to happen on the SSL hardware.
Win 7 64
SSL MX4
Old 09-08-2014, 10:59 AM
The Weed's Avatar
The Weed The Weed is offline
Try setting the sample rate for the Scarlett to the session rate, then open Pro Tools and the session. Pro Tools doesn't do a good job changing sample rates on third party interfaces.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Pro Tools could not set sample rate to specified value SixStringRockteer Pro Tools 9 4 06-29-2013 05:24 PM
Pro Tools LE 8 Sample Rate question shaolin_kobudo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-02-2009 10:55 AM
Pro Tools could not set sample rate to specified value - 7.4 LE Mbox2 Pro gbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-25-2008 01:46 PM
Pro Tools LE Sample Rate Mismatch Nag tcassel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-20-2007 12:51 PM
Pro tools free sample rate SoundWrangler Digidesign Hardware & Software 1 09-17-2002 12:34 AM
