Old 07-13-2010, 04:49 AM
clusterer clusterer is offline
Default Change all Playlists to Tracks
hi,
is there a fast way to change the playlists of one track to individual audio tracks??
thanks in advance!
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD
Old 07-13-2010, 07:47 AM
tj_davies tj_davies is offline
Default Re: Change all Playlists to Tracks
1 - make sure drop order is top to bottom
2 - scroll out so you see the grey unused area at the bottom of the session
3 - on the track go to playlist view
4 - select all audio regions you want to transfer to their own tracks
5 - hold ctrl and pull the regions out of the bin into the grey unused area at the bottom of the edit window
6 - select all audio regions you want to transfer to their own tracks again
7 - hold ctrl and pull the regions out of the bin onto the newly created tracks edit: you could also just pull the regions inside the edit window down to the new tracks!
Hope this helps,
Timothy
PS. Action 3 and 4 are only there to quickly create the correct amount of new tracks - unfortunately Pro Tools only adds the active region onto the lowest new track. But that's sorted with actions 6 and 7. When the track that holds the playlists is selecting during action 5 the new tracks are added just below that track.
G5 10.13.6
PT Ultimate 2019.12.0
www.pearls-music.com
Old 07-13-2010, 07:52 AM
spidey01 spidey01 is offline
Interesting
Old 07-13-2010, 08:33 AM
Just created a quick movie, maybe that's easier to understand than what I described above:
Click here
Hope it helps,
Timothy
G5 10.13.6
Old 07-14-2010, 12:43 AM
Hope this helps,
Timothy
Hi Timothy!
Thanks a lot - that´s great to do it so!!! I´ve tried several things like "expand alternates to new tracks" etc. but had always troulbles with that.
I love the DUC - thanks!
greg
HTML code is On
Change playlists for multiple tracks in one go tomedwardsuk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-17-2013 09:41 PM
Several songs in same session want to change order including playlists Santo Pro Tools M-Powered (Mac) 0 09-01-2009 08:34 AM
Alternative way to Change Playlists? Gammon2006 Pro Tools TDM Systems (Win) 3 08-10-2006 01:18 PM
Comp tracks [composite tracks] from playlists ??? gollywillickers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-08-2005 07:01 PM
Can You Change Playlists From Mix Window? tomhartman Pro Tools TDM Systems (Mac) 0 03-20-2004 03:58 PM
