Old 08-09-2006, 07:16 AM
Gammon2006 Gammon2006 is offline
Default Alternative way to Change Playlists?
Hey all - at some point in the past I remember working in PT and accidentally pressing some key on the keyboard and then either left or right-clicking on an audio region, and a menu popped up which appeared to be a list of the other playlists on that track. Since then I can't remember how I got that to happen, and I can't seem to find anything about it in the manual. Does anyone remember how to do this? It seems like it would be a much faster way to comp multiple takes than going back and clicking on the playlist button every 5 seconds. Thanks!
james
Old 08-09-2006, 06:15 PM
jeff markham's Avatar
jeff markham jeff markham is offline
Default Re: Alternative way to Change Playlists?
hmm .. i know Start + <- or -> will change the
track view (regions to automation etc.). i'm not sure
of one that scrolls through the playlists .. but that would
be pretty handy.
jeff
Old 08-10-2006, 08:00 AM
Ben Jenssen's Avatar
Ben Jenssen Ben Jenssen is online now
Sounds like you might be talking about the "takes list view".
Let´s say you loop record several times on the same spot, there will be several regions with the same start point, but you only see the last recorded region on the track. Now if you command-click (mac) or cnrtl-click (Win) on that region (with the region selector tool!!!), then the takes-list menu will show all regions with the same start point and you can switch takes.
I have never heard of a shortcut to change playlists.
IHTH.
Life-long audio enthusiast and small studio owner. Retired.
IMac 21.5-Inch "Core i5" 3.0 (4K, Mid-2017)
8GB RAM, 2x OWC fast SSD's on TB3 for system and audio files.
Focusrite 2i2 3rd gen, Dynaudio BM6's and a couple of old mics.
Pro Tools 2020.5, Mac OS 10.15.6.
Old 08-10-2006, 01:18 PM
nikki-k nikki-k is offline
I dont know of one either...
Takes: with 7.2, this is also accessible from a right-click on a region. A menu item, "matches" will appear, and regions falling within params set via Prefs will be available there. Very cool!
nikki k
Eagles may soar, but weasels don't get sucked into jet engines.
On the other hand, you have different fingers.
Originally Posted by nikki-k View Post
Sometimes ya just gotta put your tongue on the 9V battery just to see what all the fuss is about.
Change playlists for multiple tracks in one go tomedwardsuk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-17-2013 09:41 PM
Tempo change causing midi volume to change plugin output tgrfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2011 01:08 PM
Change all Playlists to Tracks clusterer Post - Surround - Video 4 07-14-2010 12:43 AM
Several songs in same session want to change order including playlists Santo Pro Tools M-Powered (Mac) 0 09-01-2009 08:34 AM
Can You Change Playlists From Mix Window? tomhartman Pro Tools TDM Systems (Mac) 0 03-20-2004 03:58 PM
