Automation point moving
Hi all
I have some (probably) basic questions concerning automation points 1) How can I find the value of a point without clicking on it? (pencil & grabber tools leave another point wich has to be erased) 2) How can I move a point in one direction without affecting the other? (using the + & - keys like a Nudge) 3) How can I select a string of points and edit them all at the same time? (all up/down, etc) Cheers Sparks
The pessemist is never disappointed. |
Re: Automation point moving
For 3) Select the area where you want to raise or lower the automation points. Then use the grabber tool to act on your selected area to raise or lower the volume points as you like. If no automation points are there it will still raise and lower the volume and insert points.
Good luck... |
Moving audio region without moving automation? | tokolosh | Post - Surround - Video | 6 | 04-09-2014 06:11 AM |
Four-point automation w/fades? | bleen | macOS | 1 | 02-22-2014 05:47 PM |
Moving insertion point to next marker? | IO Composer | Pro Tools TDM Systems (Mac) | 2 | 11-15-2005 12:21 PM |
Automation point resolution | Centurion | Pro Tools TDM Systems (Mac) | 1 | 01-20-2003 08:58 AM |
Moving Edit Point | altalake | Digidesign Hardware & Software | 1 | 05-24-2002 04:35 AM |
