Old 05-01-2008, 08:45 AM
crizdee's Avatar
crizdee crizdee is offline
Default Waves SSL G-EQ freezing, not compatible with Control 24
Since updating to the mew waves shell 5.9.7 i have been having this freezing problem with the SSL G-EQ RTAS version, when adjusting cut / boost from the control 24, it will stop passing audio and the meter will show max level and i have to de-activate and re-activate to get it back.
7.4 cs3 Tiger 10.4.11
Chris
Producer, Engineer,
www.ukmastering.com
Old 05-01-2008, 09:13 AM
Drew Mazurek's Avatar
Default Re: Waves SSL G-EQ freezing when tweaking! anyone else?
nope. working fine here. Did you change anything else at the same time? Maybe try pulling all plugs but waves and basic digi and see if it still does it.
www.drewmazurek.com
Old 05-09-2008, 01:43 PM
crizdee's Avatar
I've discovered this is happening when tweaking the RTAS version from my control 24, totally repeatable
Anyone with a C24 and Waves G-EQ RTAS?
Here's a video if interested...
http://www.youtube.com/watch?v=rY7V894nl3A
Chris
Producer, Engineer,
www.ukmastering.com
Old 05-12-2008, 12:15 PM
crizdee's Avatar
Been in touch with Waves support who are going to investigate!!
I have now tested further and having only waveshell 5.9.7 and stereo.mixer.dpm in the plugs folder and it still causes the issue. so no conflict with third party plugs.
This is only when adjusting the cut/boost on RTAS from the control 24! 100% repeatable (using mouse is ok)
I don't have the TDM version to check.
Anyone with a control 24 and the SSL bundle? give the gain a few swings around and see if it freezes. usually occurs with a few seconds.
Chris
Producer, Engineer,
www.ukmastering.com
Old 05-13-2008, 08:37 AM
crizdee's Avatar
Reply from waves support...
Dear Chris;
The behavior is a bug - It was reported and was confirmed by our QA as a bug.
In order to adjust the "LMF" gain and "HMF" gain you should use the mouse until this bug will be fixed.
Let me know if you need any further assistance.
Best Regards,
Waves Technical Support
Producer, Engineer,
www.ukmastering.com
Old 05-13-2008, 01:54 PM
Studio Dweller Studio Dweller is offline
I tried this briefly last night. I have the TDM SSL bundle so this may not apply, but I instanciated the RTAS version of the G-EQ and adjusted a few of the knobs via the Control|24 without any crashing. I didn't try all of the knobs, but I do know the HMF section was adjusted (gain, freq and Q). I don't remember if it was a mono or stereo version of the plug, but if you'd like me to try it again just let me know.
I'm using:
Waveshell DAE 5.9.7
Mac G5 PPC Dual 2.5 GHz (RTAS processing set to two processors, 85% CPU usuage)
OS 10.4.9
PT HD3 (Not Accel)
Pro Tools 7.4cs4
192 I/O
Control|24 (original version)
Larry
Cellar Dweller Productions
PT 2020.3.0 HDX, HD IO 16x16 analog, 192 I/O, Control|24
Mac Pro 2019 16-core, 96GB RAM, OS 10.15.2
Old 05-13-2008, 02:34 PM
crizdee's Avatar
I'm using:
Waveshell DAE 5.9.7
OS 10.4.9
PT HD3 (Not Accel)
Pro Tools 7.4cs4
192 I/O
Thanks for trying! its just the 2 gains on the LMF and HMF i think that cause the freezing.
Sometimes can take 20-30 seconds, but always goes eventually.
Anyway, waves say they have it logged as a bug fix, so hopefully they will fix it soon.
Chris
Producer, Engineer,
www.ukmastering.com
Old 05-13-2008, 05:42 PM
Perhaps I didn't let it go long enough. I just trired it again and after adjusting the LMF gain for a few seconds, I heard a click and then the singal level meter on both the plug-in and the mixer channel was maxed. Pro Tools didn't crash, I just had a pinned signal meter and no audio would pass on that channel - just silence. I could still start and stop playback and audio played back fine on another track in the session. I removed the plug-in from the channel and it went back to normal.
I tried it again with the TDM version of the plug-in and didn't experience the problem.
Larry
Eleven Rack control panel freezing MichaelUR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-04-2011 05:50 AM
11R Control Panel keeps freezing! MichaelUR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-03-2011 04:59 AM
mc control freezing norbury brook Artist Series 22 08-26-2011 01:49 AM
So, Waves 7.4 compatible or not? studiomusic Pro Tools TDM Systems (Mac) 4 12-12-2007 05:47 PM
6.7 LE compatible with WAVES 4.0.1????? mykhal c 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-29-2004 06:55 AM
