Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2020
Old 07-23-2020, 04:53 AM
lamacchiacosta lamacchiacosta is offline
Default Audiosuite preview no sound
I am trying to listen to Audiosuite plugins but there is no sound when playing back.
Pressing the loudspeaker button shows audio modulation. In the Setup I/O menu, the Audition Path is sent to the same output as Monitor path (the other menu option is "No output").
Nothing is coming out. It's not going to my sound card as there is not led lights showing up anything.
Bypass button is disengaged. Volume output is set to 0.
What am I missing, please?
Old 07-24-2020, 10:17 AM
daeron80 daeron80 is offline
Default Re: Audiosuite preview no sound
The term "sound card" raises a red flag. Windows sound card, maybe? ASIO For All driver? What OS and version, PT version, audio interface, etc?
David J. Finnamore
Nyquist was right.
PT 2020.9.1 Ultimate | Omni | macOS Mojave
PT 2020.9.1 | Saffire Pro 40 | Win10
Old 07-24-2020, 12:48 PM
He's on a Mac.
To the OP, you are right this is all Audition Path. But the IO Setup may be corrupted or just confusing to follow. You might have multiple paths with a very close name and not seeing them all in the Setup>IO window??? etc.
As always when troubleshooting the first thing to do is trash prefs.
I would do a test. Start with new empty session with one audio track and try to get this to work. If you delete and Default all your IO does this work? If you switch your Playback Engine to Built-In Output (or whatever it's called in your Mac) and delete and Default the IO does that work?
Still stuck try moving all plugins out of the plugin folder, trash prefs again and test just with the default Pro Tools plugins.
No preview sound in Audiosuite pechnatunk Pro Tools M-Powered (Win) 2 06-09-2010 09:58 AM
can't ear audiosuite preview, no sound from preview -SOLVED! sonuslab Pro Tools M-Powered (Win) 3 03-19-2008 12:51 AM
audiosuite preview / workspace preview fixed in 7.4? viaspiaggia Pro Tools TDM Systems (Mac) 10 10-11-2007 01:02 PM
Audiosuite preview sound.....??? Valeri Pro Tools TDM Systems (Mac) 1 03-27-2006 01:36 PM
audiosuite won't preview- HELP! btlguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-24-2001 03:27 AM
