Old 08-03-2020, 07:18 AM
Default Re: Loss of frequency Panning Issue
I have tried to recreate this but failed. Can you please share your system config, there must be something incompatible with it...?
Old 08-03-2020, 08:00 AM
daeron80 daeron80 is offline
How is the loss being measured? Make a fresh session with two tracks:
  1. Mono Aux with Signal Generator on first insert.
  2. Stereo Master with a FFT plugin on any insert.
Show inserts A-E and F-J to make sure no other plugins are instanciated. Also show Sends A-E and F-J to make sure no sends have been created. Set the SigGen to Pink Noise. Watch the FFT as you pan from center to side and back.
If you don't have a good AAX FFT, MeldaProductions has a set of free plugins that includes one, along with many other useful things.
If that doesn't reveal the problem, it will rule out the possibility that it's happening inside PT. It could be in the Focusrite mixer app (Control?) if you have it installed.
David J. Finnamore
Nyquist was right.
PT 2020.9.1 Ultimate | Omni | macOS Mojave
PT 2020.9.1 | Saffire Pro 40 | Win10
Old 08-03-2020, 08:23 AM
Gotta be something funky in the monitor chain/interface (not necessarily monitors themselves) or routing; maybe panning dry track into a return from an aux or something that's phase-cancelling. Would have to see the session. Certainly not a PT bug or the world would've spun off its axis long ago...
Looking again, I see Focusrite interface - I'd say 90% the issue is in either how the interface's dry/wet monitoring is being used, or something funky in the interface.
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.14, PT 2020 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 08-03-2020, 09:26 AM
Eric Lambert's Avatar
Eric Lambert Eric Lambert is online now
Originally Posted by DVTOM View Post
Its hard panned when it is heard. I bring it down to 75% it restores the frequencies back.
I understand, but we don't know the elements within your session. Have you tried the stripped-down version I mentioned above and do they give the same results?
Old 08-03-2020, 05:29 PM
I'm leaning towards a phase issue. Start by testing all cables between the interface and the speakers and make sure every TRS plug is pushed all the way in(one click out would flip phase on a balanced connection)
loss of panning and greyed out wav stems etc dobryden macOS 0 07-10-2015 03:47 PM
Mbox 2 PRO FW Noise Frequency Issue DJFAME 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-11-2010 03:28 PM
Panning Issue erik1x Pro Tools TDM Systems (Mac) 3 05-10-2009 10:28 AM
Digi 002 Rack Problem (Loss of Panning) Please Help nicksena 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-07-2008 03:36 PM
Digi 002 Rack Problem (Loss of Panning) Please Help nicksena 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-06-2008 07:36 PM
